Mathieu B.
Mieux qu'espéré!
Câble doublé pour faire des jumpers, aigu ni mou ni trop agressif, résultat parfait!
Eddy P.
Amélioration et aération
J'étais en RCA avec un octavio stream g1 sur un marantz pm 6003 et une paire de dittons 442 recapé. Le son était bien mais...
Jean Luc V.
Incroyablement bon
Ces écouteurs sont super bien réglés et délivrent un son incroyable.
Pour moins de 70 € on a absolument rien à lui reprocher.
AUDIOPHONICS DIGIRESCUE Reclocker SPDIF Module Optical Coaxial Galvanic Insulation 24bit 192kHz - reviews - There are 2 reviews.
Joris J.
Addition
This text in the description above: “ The DAC connected to the module will then receive the audio signal on its optical input." this is only true when a optical cable is used between reclocker and DAC. This reclocker can also be used as a optical to coax converter. Both optical as coaxial output sockets of the reclocker give the output signal.
Joris J.
Superb reclocker
I use optical only, so used only the reclocker of this device (galvanic separation already exists by optical connection). Sound improvement was signifanct and even astonishing when using a regulated power supply with LT3045 in it.
Thanks to Audiophonic for bringing out this product!
This Audiophonics DIGIRescue reclocker module has been designed in association with Ian Canada. Using a high-precision local clock and Ian...
