Markus W.
Good quality
Patrick v.
Magnifiques !
Tom K.
AUDIOPHONICS EVO-SABRE PACK DIY Balanced DAC 2xES9038Q2M & Streamer for Raspberry Pi 4 - reviews - There are 21 reviews.
Rupert S.
La version 2 SVP
Bonjour, ce DAC est bien noté partout ! Je l'utilise depuis qu'il est sortie et ne m'en lasse pas. Il est directement connecté à un amplificateur Audiophonics avec des modules Hypex via des connecteurs XLR.
J'aimerais voir une version II de ce DAC! Les améliorations et corrections devraient être faciles à implémenter avec le recul que nous avons à présent.
Aussi, une plaque arrière compatible Raspberry Pi 5 serait très bien venue.
Merci pour ce produit unique qui réunit tous ce qu'on peut souhaiter pour un streamer/DAC dans un boîtier compacte et à un prix abordable.
Gerhard K.
Excellent Sound
On the output I run a 2.1 system (KEF LS50 Meta + DIY subs) with 3x500W class D plate amplifiers (Pascal). I came from a RPI3 + Hifiberry DAC HD2, running on Volumio, which sounded quite good to me.
But immediately, keeping Voilumio as OS, I heard quite a difference: cleaner sound, less fatiguing in the highs, more solid image, better dynamics. I can't say it way day and night, but there clearly was an improvement that justified the cost. Even my wife who is not very audiophile noticed the difference.
The RPI4 surely contributes to the responsiveness of the system (music library stored on a NAS over eth GBit), no waiting anymore, fluent switching between library, Spotifiy, Hiresaudio and Youtube. Bravo Audiophonics and thanks!
Werner S.
Good Dac an good Streamer wenn you find the right operation system
Well I had ordered the new Evo-Sabre as a complete kit at the beginning of February 2023 and it arrived within a week.
For the assembly it needs already some idea and also patience. Except for a wrong drill hole, which had no meaning, I could assemble everything well and also the first test was positive. The device looks good overall and makes a quality impression. Finally Audiophonics has a solution to switch the device on and off via a real hardware switch, including the Raspi, which is always running. The Dac itself is very quickly ready for operation and displays the sampling frequency, the selected input and the volume. The Raspi is accessible after about half a minute. Switching off or shutting down takes only a few seconds.
I took a lot of time with the choice of the operating system. First I tested the ready-made images offered by Audiophonics. The following comments are brief:
Volumio: makes at first a quite passable impression, but even after longer trying and reading in the forum, my embedded art covers could not be displayed correctly.
Moode: didn't work for me, especially the integration of my music collection didn't work and the cover images weren't displayed.
DietPi: altogether also not successful and only after much reading I got further so that at least the LMS server ran.
Then I downloaded the latest PiCorePlayer and from then on everything worked as I wanted. So this is the operating system of my choice. I could also set everything with a little reading up immediately and according to my ideas. After that, the LogitechMusicServer ran immediately and it was displayed, for example, all my cover images. I use for operation on the smartphone (Android) the Material Skin with the Kiwi Browser, which looks very good and also provides a lot of additional information about music and artists with the appropriate selection of plugins. I must say that I already knew and used the LMS before, so it was familiar to me again quickly.
The right display have not brought to run, but in the forum there is a script where it should be possible. I do not need the (right) display, because I see everything via the smartphone app.
Summary: overall a good device that I would buy again. The price is reasonable for me especially as a complete kit with Raspi. The converters are also very good and it sounds very nice in my very high quality system.
My request to the Audiophonics team would be to adapt the illustrated instructions to the current state and to give more instructions in a few places (e.g. installation of the display cover).
It was very good for me that I received several answers to my questions about details in advance (before I ordered the device). Thanks for that.
Frank G.
Evo evolution
Well at first I was a little disappointed. The sound didn't impress me. As special the dynamics. This improved a lot after some playing hours. I was always a bit skeptical on run in time for audio equipment...but I have to revision my opinion now. The setup with volumio and Spotify was a bit of a hassle, a lot of lost connection issues. But since I learned howe to clear the que in volumio that is solved. I sure like the clarity the highs are crisp without a harshness. The mids are more convincing. The bass improved a lott with the dynamics over time. All compared to my Yamaha wxad 10 with burr brown chip. Conclusion; I can recommended to everyone with a little persistence on the setup and run in time.
Grégoire N.
Trés bon appareil
Le montage ne présente pas de difficultés particulières ; il faut juste veiller à bien brancher les nappes - une erreur de ma part à ce niveau m'a valu de devoir faire appel au SAV d'Audiophonics qui s'est montré efficace et sympathique.
RAS coté son : ça marche très bien. Petit bémol toutefois sur les pleines performances (DSD256 et PCM 32-bit 768kHz) exploitables uniquement via le port USB-B : c'est un peu dommage puisque l'intérêt majeur de cet appareil et de combiner DAC et lecteur réseau (lequel ne peut exploiter le DAC qu'à hauteur des formats DSD128 et PCM 384kHz).
L'ergonomie à l'utilisation est très bonne (même si l'intégration linux reste perfectible sur quelques détails comme l'arrêt du système).
En conclusion, ce DAC est donc un appareil tout à fait satisfaisant auquel j'attribue volontiers cinq étoiles.
Laurent B.
Excellent
Après le Raspdac mini, j'ai choisi l' Evo-sabre pour le câblage de mes HP Genelec (Symétriques) .
Un régal de précision, image stéréo bien définie.
J'ai rajouté un radiateur (Geekworm Raspberry Pi 4 Embedded Heatsink with Fan) pour le raspberry (sans le ventilateur) il s'adapte sans problème .
Bernard g.
Excellent produit
Je voulais m'offrir un lecteur Reseau/Dac pour le relier à une installation vintage (années 90) : Ampli Luxman A384 ; enceintes BC Acoustic Tibre.
Dans ce cadre, le prix était un élément important.
Au final , je me retrouve avec un produit excellent .
Le Dac est meilleur que mon Atoll Dac 100 (2014) + Armature Hecate.
Les aigus et les mediums sont magnifiés en particulier sur les vieux enregistrements qui pêchent sur la prise de son (sifflantes, aigus exacerbés).
Même si les basses sont un peu écourtées dans certains cas , elles restent tendues et belles.
Merci à Audiophonics de mettre à disposition des produits DIY de cette qualité et leur soutien technique rapide et efficace.
Edern A.
Excellent streamer avec un son magnifique
Après plusieurs heures d'écoute, voici mes impressions sur le Evo Sabre.
Tout d'abord, le montage de l'appareil est extrêmement simple et ne présente aucune difficulté car il est bien documenté (c'est juste dommage que le manuel ne soit pas fourni sous forme papier). L'installation d'une image système demande un peu plus de travail mais, grâce à l'aide rapide et bienveillante du SAV, c'est faisable également.
D'un point de vue esthétique et pratique, je trouve que l'appareil est une réussite. Il est compact et pratique. Son look, un peu high tech avec ses deux écrans, est vraiment agréable à l'oeil. C'est vraiment sympa de voir s'afficher le nom de l'artiste et du morceau ainsi que le temps des morceaux qui s'écoule.
La télécommande est pratique même si j'ai parfois l'impression qu'il y a un petit décalage entre le volume sonore affiché sur l'Evo et celui de Volumio.
En ce qui concerne le son maintenant :
Avant d'acheter l'Evo Sabre, j'utilisais un Raspberry 3b+ avec un dac Topping D10 raccordé en USB. J'ai remplacé ce setup par l'Evo Sabre. Dans un cas comme dans l'autre, je lis des fichiers FLAC stockés sur un disque dur externe et la partie logicielle est confiée à Volumio (plus simple à prendre en main et configurer que Moode).
L'Evo Sabre apporte un net gain par rapport au setup que j'utilisais auparavant ! Je prends plaisir à réécouter la musique en y découvrant de nombreux détails que je ne percevais pas. Le son est très bien défini, minutieux, avec une belle distinction entre les différents éléments qui composent les morceaux, que ce soient les instruments ou les chants. Autre aspect notable : les basses sont bien meilleures qu'avant. Elles sont fermes et profondes mais équilibrées, elles ne viennent pas écraser le reste.
En gros, la musique est plus nuancée, très bien étagée, très bien articulée, ce qui est sans doute à mettre au crédit du fonctionnement en double mono.
L'entrée Bluetooth produit également un excellent son. Sachant que ce n'est pas l'entrée la plus qualitative (la faute au faible débit de données du bluetooth), c'est une très agréable surprise d'entendre un son de bonne qualité en sortie.
Je n'ai pas essayé les autres entrées (coax, optique, etc.) mais j'imagine que le résultat est de la même trempe.
Je recommande vivement ce streamer qui a de nombreuses qualités, au premier rang desquelles un son vraiment excellent !
Daniel B.
Parfait ! Merci AUDIOPHONICS :-)
Un ensemble de grande classe, avec des fonctions à foison, et une sonorité digne de produits de "grandes marques".
Je l'utilise avec un ampli casque classe A, et un casque AUDEZE LCD2, le tout avec des fichiers en HIRES sur mon réseau local.
Le rendu est tout à fait excellent, le DAC est vraiment très bon.
De plus, ce système est ouvert à des plugins et de futures améliorations !
Pour terminer, je tient tout particulièrement à remercier et féliciter le SAV AUDIOPHONICS : réactivité, excellente communication, connaissance parfaite du système, permettant une mise en route en toute quiétude, que demander de plus ?
john p.
Relaxed sound
This product lies outside the general rule “you get what you pay for”. As a standalone dac tested with optical ,coaxial, usb inputs sounds really good. I am not afraid to say it stands close to far more expensive R2R dacs I had the chance to listen to. My ongoing concern with digital has always been the listening fatigue ,this bombarding and exaggeration of microdetails that messes with your brain. This dac is a different story.
The RPI4 is a fantastic streamer transport and with the I2S connection to the dac sounds fantastic. Tidal HiFi in most cases sounds really good. (MQA is not my thing)
I have tested standard 16/44.1, higher sampling rates and DSD. My preference remains standard 16/44.1 and DSD through Volumio.
Being a vinyl fan from my early days and having accepted the pros and cons of this format I got lucky to run into this “desktop” sreamer-dac that gives me 4-6 hours of daily music listening without any fatigue. XLR output to a Luxman L550axII feeding a pair of heavily modified old Klipschorns and there you are !!!
A great combo from the Audiophonics guys!!
Cyril V.
AUDIOPHONICS EVO-SABRE PACK DIY avec Roon Labs
Acheté début 2020, j’ai pris le temps de tester l’AUDIOPHONICS EVO-SABRE PACK DIY DAC Symétrique 2xES9038Q2M.
Avec l’entrée USB je suis déçu, le son est moins percutant. Je ne serai dire pour quelle raison, surement ma source USB (Serveur NAS ou Raspberry PI 4) ! De toute façon, je ne souhaitais pas utiliser cette entrée en l’achetant.
Le résultat est meilleur avec le Raspberry PI (interne au boitier utilisant les GPIO en I2S). Le son est dynamique, précis sans être analytique comme les autres DAC Audiophonics DIY utilisant également l’ESS SABRE 9038Q2M. Je pense que c’est lié au filtre a phase linéaire et ou la gestion du DPLL.
J’ai changé les AOP de sortie par des BURSON AUDIO SUPREME SOUND SS OPAMP V6 Classic AOP Simple (pour info, pas besoin d’adaptateur). A mon oreille cela n’a pas changé grand-chose (A l’époque où j’avais changé les AOP j’avais des enceintes et un ampli bas de gamme de 20 ans d’âge).
J’ai mis en place un dissipateur thermique sur le Raspberry Pi 4 qui s’intègre bien entre le PCB et le PI (Geekworm Raspberry Pi 4 11mm Embedded Heatsink (P165-B)). Ce qui m’a permis de gagner quelques degrés.
J’alimente le DAC avec l’alimentation proposé par Audiophonics (MEAN WELL Adaptateur Secteur Alimentation 100-240V AC vers 9V 4A DC ) avec un filtre ifi
J’ai remplacé l’écran de droite SPI par un écran DSI en couleur et tactile de 4,3 pouces (4.3inch DSI LCD Capacitive Touch Screen Display 800×480). J’ai dû le coller avec du double face en façade. Ce n’est pas des plus esthétique (ce n’est pas moche non plus) mais c’est fonctionnel. Je vois les jaquettes, je peux passer au morceau suivant, diminuer ou augmenter le son en appuyant sur l’écran.
Utilisateur de Roon, j’utilise la distribution Ropieee qui s’intègre parfaitement au DAC notamment la gestion du volume, l’écran tactile DSI (non SPI). J’ai testé d’autres distributions, Ropieee tien le haute du pavé avec Volumio en termes de restitution sonore.
Pour info, j’utilise ce DAC comme préamplificateur sur un amplificateur Audio-GD A1 et depuis 3 semaines sur des enceintes Triangle Magellan duetto. Le tout sonne très très bien.
Les plus :
- Rapport qualité prix
- Qualité de fabrication
- Pas mal d’entrées (GPIO(I2S), USB, TosLink, SPDIF, Bluetooth)
- En sortie XLR et RCA
- Module DAC symétrique Double ES9038Q2M
- Possibilité de choisir les AOP de sortie
Les moins :
- RPI I2S : 384kHz / DOP128. J’aurai préféré une liaison DSD Direct 512. Est-ce que c’est possible avec le Raspberry PI ? ou Est-ce lié au FGPA Altera Max ?
En conclusion
Très bon produit en therme de son. J’ai aimé le monter moi-même et le modifier pour mon utilisation (Roon Player). L’intérêt de ce produit est le prix, l’électronique de bon niveau, la flexibilité d’utilisation, mise à jour à moindre frais. Si Apple sort un nouveau protocole Airplay 3 (implémentation dans l’OS) ou un futur Bluetooth 6.0 (via clé USB ou changement du RasPI) vous pouvez mettre à jour après que la communauté est sortie la mise à jour.
Gernot E.
A delight for audiophile ears
The unit is easy to assemble, helped by very clear illustrated instructions. The quality of the housing is very good, the aluminium surfaces are beautifully brushed and all parts fit together perfectly.
The sound quality is outstanding, and the display with the large ticker showing the metadata of the music currently playing is also very nice.
The documentation of the DAC functions and the remote control can be found in the article description of the DAC board ("Datasheet Evo Sabre"). Unfortunately, this documentation leaves many questions unanswered and some of the items in the settings menu that are accessible via the remote control are not addressed or are perhaps no longer up to date.
Example: According to the documentation, the Raspberry Pi cannot control the power supply state of the DAC board. But in the settings menu, the item "GPIO Power Control" (not mentioned in the documentation) appears, which, when set to "yes", seems to let the Raspberry Pi shut down the device in a controlled manner.
Conclusion: A beautiful and high-quality device that is a lot of fun. However, the documentation could be improved.
 (3)
Andreas D.
Pure High Level Sound
I'm running it for a couple of months. It's paired with a Trigon Energy Amp through XLR and the sound is amazing! For me is the sound much more better than from the Lindemann Limetree Network and the Lumin D2. I had both of them! I only use the free version of Volumio, because I'm just streaming from a NAS. Even If you are not familiar with PI or DIY give IT a chance...it's realy easy!!!
Philippe J.
Parfait
Montage rapide et bien documenté (attention toutefois à la partie écran, pour ma part j'ai surement oublié un film ..)
Très fonctionnel avec sa télécommande, la qualité est au rendez-vous, je découvre des sons qui était quasi inaudible avec mon ancien système.
Un petit bug de son, manque d'intensité au démarrage mais reprend de la vigueur en utilisant le gestionnaire de volume de l'application volumio. Curieux.
Esthétique de qualité.
Je conseille.
Jean Pierre F.
Correction sur mon avis précédent
La réactivité d'Audiophonics est exemplaire, j'ai reçu en tout début de matinée une réponse positive avec le lien pour la notice parfaitement détaillée. Je précise qu'il ne manque rien par rapport au montage préconisé.
Juste une petite remarque sur le soin porté à l'emballage et cette petite griffure sur la face avant sinon pour le reste c'est nickel.
Arnaud F.
Très très bon dac Français !
Je suis très ravi de mon dac.
Le fait de monter soi même son dac est ludique et très facile à mettre en œuvre.
Toutes les pièces sont de très bonnes qualités et tout se montent facilement.
J'ai associé à l'evo-sabre, son alimentation audiophonics dédiée pour mieux l'alimenter.
Le dac est branché sur un préampli Atoll Pr200se, un ampli am200 signature Atoll avec des câbles rca Canare.
Mes sources sonores viennent de Qobuz.
L'écoute est très belle, la scène sonore est ample sans agressivité avec des graves présents mais non envahissants, des médiums et aigus bien définis sans être criards.
Je le pilote grâce à bubbleupnp (très bonne application avec un développeur très réactif) depuis mes appareils Android.
Pour le faire fonctionner, mon choix s'est arrêté sur Volumio qui me donne sur mon installation, le meilleur résultat: scène large, écoute de chaque instrument détaillé, grave présent et bien défini, médium et aigu sont agressivité et donc pas de fatigue à l'écoute.
L'écoute est également détaillés avec beaucoup d'informations et de précisons.
De plus, avec volumio s'est très facile à installer et l'utilisation est quasi immédiate après l'installation.
J'ai fait d'autres essais pour piloter le EVO-SABRE.
Avec MoOde: je n'ai pas du tout aimé, la scène était trop centrée ce qui faisait que je perdais la largeur de la scène, tout semblait confus, beaucoup moins défini, un gros bof !
PiCorePlayer: moins facile à installer que Volumio ou MoOde mais avec les tutos que l'on trouve sur leur site, cela se fait facilement quand même.
L'écoute est agréable, les graves sont encore plus précis que Volumio mais la scène est beaucoup moins large et n'utilise pas tout l'espace possible entre les enceintes.
L'écoute est également moins détaillés moins analytique.
Par contre point de vue utilisation depuis un appareil, c'est beaucoup moins pratique qu'avec Volumio ou MoOde grâce à bubbleupnp.
Si je n'ecoutais que du rock, funck, jazz, je crois que mon choix pourrait resté sur PiCorePlayer mais comme j'écoute énormément de musique musique classique en plus de celle citées avant, ma préférence va pour Volumio pour sa largeur de scène sonore et à la présence de beaucoup plus de détails.
Par contre, j'ai un petit reproche à l'utilisation du EVO-SABRE avec bubbleupnp, c'est la durée de la mise en place d'une playlist à cause de la version du openhome dans l'image Volumio proposée par audiophonics.
Mais grâce à la très grande écoute de ses clients et à la très grande réactivité de leurs services, ce petit reproche devrait être corrigé dans une future mise à jour de la version Volumio.
Une dernière remarque, c'est l'immense qualité de service chez Audiophonics, je n'ai jamais rencontré une entreprise sur le net qui soit autant à l'écoute de ses clients et qui cherche à aider, résoudre les problèmes avec autant de gentillesse, d'écoute et de professionnalisme.
Vive le fabriqué en France et bravo à Audiophonics !
Ian S.
Excellent product
I've been using the Evo Sabre DAC for a couple of weeks now. Putting together the kit was straight forward and once I found the Audiophonics version of Volumio the displays worked too!
As to sound quality it is excellent. I've recently used DAC streamers from Auralic and Blusound and it safe to say I'm very happy with this purchase. In my opinion it's better than the Blusound and on a par with the much more expensive Auralic. Couple with the Audiophonics nCore power amp it makes a very cost effective and brilliant system.
 (3)
Thierry P.
Superbe qualité (matériel et ecoute)
Le montage est très simple et bien documenté.
Seule remarque, ne pas serrer trop la bride du connecteur de la rallonge de la carte Micro SD. Un trop fort serrage a tendance à bloquer le coulissement de la carte et éventuellement en perturber la lecture.
L'écoute est fantastique, bel upgrade sur mon ensemble vintage Quelle vivacité et justesse des timbres.
Par la liaison USB d'une tablette PC et Foobar2000 c'est à couper le souffle.
Pour une utilisation ludique avec smartphone, je me suis limité à Volumio pour l'instant.
Jérôme F.
Superbe DAC
Je l'ai pris pour servir de DAC via RJ54 et surtout pour améliorer ma platine CD en sortant en coaxial.
L'amélioration est nette au niveau de la spatialisation et aussi du rendu de grave !
Cerise sur le gâteau, les web radio via moode et je commence à mettre les mains de le cambouis avec DietPi qui offre plein de possibilités.
Gabriel A.
Le boitier ultime ?
Cela faisait quelque temps que je cherchais un lecteur réseau/préampli/DAC avec quelques caractéristiques spécifiques:
- sorties XLR
- lecteur réseau "open-source", ici avec un Raspberry
- DAC de qualité
- pilotable via télécommande
Je dois dire qu'au vu de la fiche technique, ce modèle était idéal. De plus, chapeau à Audiophonics, vous montrez les mesures et faites tester certains de vos produits sur Audiosciencereview. A l'heure où nombre de marques audiophiles ne montrent quasiment pas de mesures, ça fait plaisir.
Ma chaine hifi: enceintes amplifiées Rowen AT1 (les ancêtres des PSI A215M), lecteur CD usb Asus Impresario, platine vinyle Stanton ST150 (sorties SPDIF). Il faut dire que les enceintes sont très précises et ne pardonnent pas un mauvais maillon.
L'assemblage: est relativement facile pour une personne comme moi qui a déjà monté des ordinateurs. Il y a eu une erreur de vis (la mauvaise dans le sachet) mais c'est entré en ordre avec Audiophonics facilement (très bon service d'ailleurs)
La finition du boitier respire la solidité. c'est beau, on a envie de le mettre en avant. Rien à dire.
La configuration du lecteur est facile, mais étant habitué au monde Windows en X86, allumer et éteindre un ordinateur se fait souvent à chaque utilisation. Ici j'ai eu le souci qu'en gardant cette habitude, le système d'exploitation ne fonctionnait plus au bout de quelques jours. J'ai donc changé la physolophie et je laisse le DAC H24 allumé. J'ai installé l'image Volumio modifié par Audiophonics, cela marche impeccablement.
A utiliser c'est très facile, le produit se pilote facilement. L'utilisation à la télécommande fonctionne très bien.
Le son ? Rien à dire. Il suffit de voir le test sur Audiosciencereview pour voir que ce DAC est très bon. Gros avantage: j'ai littéralement aucun souffle provenant du DAC. Il faut vraiment coller les oreilles aux enceintes pour entendre un petit frrrrrr mais c'est du aux enceintes.
Deux points d'améliorations à mon gout:
1) pouvoir dimmer la puissance des écrans
2) ce souci étant lié à la plateforme raspberry et Audiophonics n'y peut rien: avoir un stockage en SSD via connexion PCI-E. En esperant que le prochain Raspberry 5 le fasse et que son format soit au milimètre près le même que le 4 pour facilement upgrader. En effet, le stockage via micro-sd est assez lent.
En résumé: un excellent produit au très bon rapport qualité/prix.
Luis G.
Produit exceptionnel.
Il diffère des auteurs DAC par une qualité sonore supérieure. Grâce au FPGA ALTERA MAX2 avec deux cristaux 44,1x et 48x. supprimer le jitter des entrées USB, Raspberry PI ou Bluetooth.
De nos jours, c'est un grand avantage d'avoir un DAC avec entrée IP sans jitter. Avec radio Internet et musique NAS.
C'était très facile à faire pour moi.
Here is the complete kit version of the EVO Sabre with all the elements (electronics + box + options including Raspberry Pi 4, remote control &...
