Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
AUDIOPHONICS JDC-125 Power supply cable Jack DC 2.5mm to DC 2.5mm 1m - reviews - There is 1 review.
Michel M.
fais le job
parfait
This cable has been assembled by us in the Audiophonics workshops to allow you to enjoy the quality of the Elecaudio range at a lower cost. The...
