Giovanni B.
Purchase
Dear Sir, my package will arrive as soon as everything is available, or will you ship what is already in stock first? Let me...
Juha K.
Excellent
This amplifier could be described as very versatile for different music genres. Purifi has never disappointed my own ears. This...
Eric H.
Fiches RCA de qualités
Très bonnes prises RCA de très bonnes qualités.
Le seul bémol c’est la soudure de la masse sur le corps qui n’est pas...
AUDIOPHONICS PRE-A Class A Preamplifier Volume Control & Source Selector - reviews - There are 18 reviews.
Sasha V.
Wonderful device.
Very well built enclosure with a nice, smooth finish, with a tactile and linear volume pot. I did also experience some hum through my speakers but that was fixed by removing the earth connection in the power cable. There is no need to open up the preamp to disconnect the earth. Now it is silent.
It requires a few days of break-in, thereafter the sound becomes much more refined and spacious. It is a really enjoyable listen, smooth and non-fatiguing with excellent detail retrieval and well controlled transients. Tonal timbre is also excellent.
Digging a little deeper, this board appears to be based on an Accuphase C3850 design, although I can't be 100% certain. Nothing to complain about here, it sounds fantastic.
It has a lot of gain - so much so that I reduced my pc output gain by -8db otherwise you don't get to use more than 1/4 of the volume pot sweep range.
My front end consists of toslink from pc feeding into a Audiophonics DigiRescue reclocker toslink to coax converter, a SMSL SU-1 dac fed via coax and rca out to this preamplifier going into active studio monitors with rca cables. This combination is the finest sounding front end I've ever owned. The law of diminishing returns applies here and I feel I would need to spend multiples more to improve my front end.
The preamp on its own is already a great improvement to sound quality, but if you can rig it up like I did you will be in for a surprise. This is my best hifi find for 2023 and I can highly recommend it. Thanks!
Eric L.
Très bon
Se complète parfaitement avec l’ampli MPA-S125NC, justesse des timbres et transparence… ce que l’on demande à un bon préamplificateur.
william l.
Euh ! comment vous dire...
Comme d'habitude, livraison rapide.
Produit qui à un aspect assez qualitatif, mais avec pas mal de soucis...
1/ Buzz dans les enceintes.
2/ Fuite du son sur la position "Mute".
3/ Sérigraphie du sélecteur de source qui ne correspond pas aux entrées RCA...
J'ai bien vu dans les commentaires, qu'il était possible de remédier au souci de Buzz en modifiant le potentiomètre de volume, mais pas vraiment habile pour ce genre de chose. De plus, je ne savais pas que j'étais un acheteur/testeur/réparateur...
 (4)
Jean-Marie L.
Bon rapport Q/P
Un souffle audible dans la voie aigue, mais qui ne s'entend plus lorsque le CD joue. Buzz gênant qui peut se résoudre très facilement en déposant le potentomètre , et en supprimant le petit fil soudé sur le haut du potar = plus de boucle de masse, plus de buzz. Le son est agréable, sans agressivité sur mes compressions pavillonnées. (BMS 4590);
Pour un prix raisonnable, on a une écoute sympathique et sans agressivité.
Danitza P.
Excellent préampli
Audiophile depuis plus de quinze ans, et client depuis de nombreuses années, n'ayant jamais été déçus par le professionnalisme des gens de chez Audiophonics, une fois encore cela c'est avéré exact.
Contexte: après avoir envoyé un mail à M. Aubert lui expliquant que suite à la mise en réparation de mon ampli intégré habituel (Cambridge Audio), j'ai mis en service un petit (mais puissant) ampli de classe D (SURE A2100 Explorer), afin d'alimenter mon système à base d'enceintes larges bandes (Fostex), d'un caisson JBL, d'une platine Marantz et d'un lecteur numérique FIIO, le tout orchestré par un Mini DSP 2X4 HD. L'écoute du classe D par rapport à mon ancien ampli s'avérait très neutre et plaisante avec une belle qualité des timbres, mais à mon gout manquait d'un poil de dynamisme.
L'achat d'un préampli pour vitaminer tout ça, me paraissait indispensable (c'est souvent ce qui ressort avec les amplis classe D, ou l'ajout d'un préampli apporte une réelle plus-value à l'écoute).
C'est donc en ayant suivi ses conseils que j'ai acheté ce préampli j'ai donc reçu l'appareil de "format moyen" (ni tout à fait compact, ni au format habituel des appareil hifi). Ce dernier s'avère excellent dès les première notes (Classe A oblige), transparent, très dynamique, facile à utiliser. ça a radicalement changé mon système. De très bon, il est passé à excellent. La qualité de fabrication n'est pas en reste: boitier, boutons… et mention + à la connectique très qualitative. Seule la LED rouge en façade est un peu dérangeante, elle éclaire trop… (c'est malheureusement souvent le cas avec les appareils d'aujourd'hui).
Pour le prix, vous pouvez y aller les yeux fermer, vous ne le regretterez pas, je pense même qu'il rivalise sans soucis avec des appareils beaucoup plus chers.
Merci et bravo à toute l'équipe d'Audiophonics.
Jean-Marie M.
excellent préampli Class A
acquis sur la baie en occaz mais comme neuf... emballage au Top ! superbe équilibre, la matière est au rendez-vous doté d'une très bonne dynamique. la finition est également parfaite; merci Audiophonics pour ce produit rapport/qualité prix difficile à battre ... couplé avec un bloc de puissance Sony TA-3130F
János S.
NICE!!!
Hi everyone.
This amp. Is very good, sound is Amazing.
I use with musical fidelity v90 dac and b&o icepower digital power amp. My speakers is diy markaudio fullrange boxes. Thx audiophonics!!!
Christian C.
Excellent préampli.
Rapport qualité/prix imbattable. Musicalement bien supérieur au L-PASS2 et largement aussi bon que le Audio-GD A2. Il redonne vie à deux amplis Rega Exon3 qui attaquent des enceintes 3 voies perso équipées d'un boomer 30cm, d'un médium à dôme Visaton et d'un tweeter également à dôme Athom.
Pour conclure, encore du très bon matériel Chinois.
Patrick M.
Etonnament musical!
En remplacement d'un préamp A/V Yamaha.On passe de la hifi au monde du plaisir musical.Excellente qualité des timbres(classe A oblige),dynamique vrai non exagérée idem pour la rapidité et la réponse transitoire.Scéne sonore large , pas de trou central et bonne profondeur des plans sonores.Se marie trés bien avec un bloc carver pm-1200.Pour ma part il n'est pas trop sensible au cable secteur(occ audiophonics)mais révèle les qualités ou les défauts des cables de modulation:les différences sont énormes.Le son est plein il a du poids presque comme dans la réalité:cela sonne vrai, ç'est naturel.Aprés avoir fréquenté quelques salons hi-fi j'ai toujours été impressioné par les prix jamais par la musicalité, exception faite de quelques constructeurs qui savent reproduire la musique et pas que des sons!Le prix est inversement proportionnel à sa musicalité!Trés bonne réalisation du coffret, ç'est relativement lourd pour la taille et les fiches rca sont d'excellentes qualité.Par contre j'ai trouvé l'emballage pour ce produit un peu cheap et un vis à l'arriére du préampli pas complétement vissée.Sinon hyper satisfait!
Didier V.
Suite et fin du raccordement masse / terre
Suite à mon commentaire précédent sur le problème que j'avais rencontré à cause du raccordement entre la terre et la masse dans l'amplificateur et qui provoquait un ronflement désagréable, j'ai poursuivi mes investigations. Dans un premier temps j'ai remplacé les colonnettes et vis en métal qui relient la carte au boitier par des versions en plastique. Mais le contact terre/masse était toujours présent. J'ai donc démonté petit à petit tous les éléments entre la carte et le boîtier et le fautif était... le potentiomètre de volume. Le fabriquant à tiré un fil au niveau du petit circuit imprimé du potentiomètre qui relie la masse avec le corps métallique du potentiomètre (à la base du pas de vis). Bonne idée si l'ampli n'était pas équipé d'une terre, mais là c'est dommage car comme dans mon cas cela peut créer des boucles de masse préjudiciables. J'ai donc retiré cette liaison et tout est rentré dans l'ordre. Maintenant mon ampli est bien équipé d'une terre et d'une masse indépendantes et ses qualités sont toujours à la hauteur.
Didier V.
un rapport qualité/prix imbattable
Ce petit préampli donne vraiment de très bons résultats. Il délivre un son très clair et détaillé bien plus agréable que mon préampli home-cinéma Marantz. J’ai eu juste un problème au début car la masse et la terre sont reliées dans le préampli et chez moi cela générait un ronflement désagréable (la connexion est faite au niveau des colonnettes qui supportent la carte électronique selon Audiophonics). En attendant de faire mieux, j’ai isolé la terre au niveau de la prise secteur et tout est rentré dans l’ordre (merci pour les conseils d’Audiophonics toujours très réactif).
Pour être parfait il faudrait à ce préampli une sortie casque intégrée ou une double sortie du préampli pour brancher un casque externe. Sinon au niveau des petits points d’amélioration, le bouton de sélection des entrées n’a pas de repère ce qui n’est pas très pratique pour voir l’entrée choisie et la quatrième position de ce sélecteur est dans le vide ce qui permet d’avoir un mute mais pour ma part j’aurais préféré une quatrième entrée. Pour finir dans le détail, la LED rouge en façade est très puissante, un peu trop à mon goût.
Pour la qualité de fabrication il n’y a pas grand-chose à dire : boitier métallique solide, carte électronique bien montée et sans reprises mais quelques traces de solvants ou autre produit (sans gravité). Mon seul reproche serait dans le raccordement de la carte aux prises RCA. Les soudures sont limites (soudures froides) et la masse est soudée directement sur le corps de la prise et non pas sur une cosse (quel dommage car en plus ils ont dû avoir un mal fou pour souder ces fils !).
En conclusion : un rapport qualité/prix imbattable.
BRUNO B.
tres bien construit !
surpris au déballage du colis, le pré, emballé avec une feutrine translucide et pas dans un carton spécifique , mais bon, c’était très bien fait ,
bien construit, cela respire la qualité , fiches rca premium , le rendu est tout simplement musical !
dommage, pour la led rouge en façade, en vert ou pas du tout aurai été mieux pour moi ! sinon au regard du prix, on a là ,un pré-ampli de grande qualité ! merci a vous
Salvatore c.
Good pre class A with BJ
Good pre class A with BJ discrete components you need to make it play for at least 200 hours before enjoying its sonic qualities. Wide range and yield, excellent speed.
Antoine S.
Le vilain petit canard
Ne vous fiez ni à sa petite taille, ni à son petit prix, ni à son esthétique simpliste, sa force est sa grande musicalité.
Il restitue une large scène sonore, ou chaque élément est à sa place, de façon détaillée et précise, avec une certaine douceur, et avec une belle gestion de la dynamique. Il dispose d'une connectique qui respire la qualité. Un fois poussé son interrupteur sur ON il ne vous apporte que du plaisir :-)
Merci à Audiophonics pour ses conseils et son catalogue de matériel qualitatif à tous niveaux de prix.
Michel R.
Excellent préampli
Sans parler du rapport qualité-prix tout simplement bluffant, c'est dans l'absolu un excellent préampli, sans coloration particulière, mais d'une grande musicalité, et d'un grand silence de fonctionnement.
On l'oublie au profit de la musique, et c'est une qualité.
Il lui faut toutefois une bonne douzaine d'heures de rodage, au début l'image sonore paraît assez plate.
Et je pense qu'il va encore s'améliorer avec le temps.
Belle qualité de fabrication, du sérieux.
Michel M.
Exceptionnel pour le prix
Une fois testé et choisi le bon cable de modulation surtout
en amont de ce préampli, ce préampli délivre un un rendu sonore exceptionnel pour son prix.
Ce rendu combine une certaine douceur, c'est vrai, un grand confort d'écoute mais aussi une transparence étonnante, une matière très agréable et des timbres d'une grande justesse. La dynamique n'est pas oubliée mais comme le reste, le naturel prime et la stricte analyse fait place bien heureusement au plaisir de l'écoute, qui est grand. Du délié, de la souplesse, j'aime beaucoup...
Par sa petite taille ce préampli est trés agréable dans la pratique, les prises sont d'une grande qualité, les commandes respirent le sérieux. Ce préampli présente une bonne marge de progression en jouant sur les cables, la nature des supports et éventuellement en mettant des pointes, mais les pieds d'origine sont excellents.
Pieter T.
good for the price, not totally transparant
Good for the price, but if you want total transparency, go for a more expensive preamplifier (this one makes the sound softer and a bit less detailed)
Vincent B.
Rapport qualité prix au RDV
Merci à AUDIOPHONICS pour la rapidité du suivi de la commande et de la livraison.
Audiophile non spécialiste, je suis très satisfait de ce préampli des plus simple à utiliser à un tarif attractif. Sa capacité à se faire oublier me semble être une de ses qualités. Douceur et clarté sonore sont bien présentes. Remplace avantageusement un ancien Advance acoustic MPP206 notamment pour le réglage du volume beaucoup linéaire et progressif. Les possibilités de connexion se limitent par contre à 3 sources d'où 4 étoiles.
This is an accurate, compact preamplifier with source selection (three inputs) and analog volume control. It works in class A for clear and...
