Jean Louis d.
ALIMENTATION
l'ampli est bon mais l'alimentation est une daube , celle si perturbe beaucoup le rendu , j'ai installer une...
A H.
OMG
I got: seat at the mixing desk
I paid: the bass
And I love this
Lennart H.
AUDIOPHONICS PRE-TC10 Preamplifier with Tone Control 2x AOP LM49720NA - reviews - There are 13 reviews.
marco g.
PRE-TC10review
I have used this excellent pre for a diy project where TC-10 drives Nr.2 DSP Tinisyne managing two full 2.1 systems. Perfect for a lot of DIY projects where an high quality preamplifier is needed. Thanks Audiophonics, always a reference.
Pavel M.
PRE-TC10 review
I have posted a review of this recently bought product at ASR:
https://www.audiosciencereview.com/forum/index.php?threads/audiophonics-pre-tc10-preamp-with-tone-controls-review-and-measurements.44930/
The preamp function is good at affordable price, it is helpful especially in cases we use a record player or cassette recorder. However, there was a QC failure with this product, the negative voltage regulator LM337 did not work and sent -23V to the LME49720 negative supply pin. This, together with +14V positive supply (correct value) made total supply voltage of 37V and this exceeds datasheet absolute maximum value which is 36V. The op amps have survived and I have replaced the faulty LM337 for a new part. However, this should have been tested by the manufacturer.
Jean Marie L.
PETIT EGALISEUR BIEN UTILE
J'ai intégré le TC10 entre un DAC et des enceintes actives et cela m'a permis de conserver mes enceintes qui n'avaient pas de réglage de tonalité
Donc objet précieux et rare pour ceux qui ont besoin comme moi d'augmenter les HF et de modérer les BF pour (bien) entendre...
Merci AUDIOPHONICS ...
Luis V.
Perfect for a Headphone System
I Had this product in the shelve for a long time because i had not found a good use for it, But when I bought an amplifier set for headphones I found the perfect match to integrate this preamp, the tone controls make all the difference.
philippe d.
Petit boitier qui fonctionne correctement
Qualité sonore acceptable. Voyants rouges trop lumineux. Je l'utilise pour seulement une écoute à bas niveau (ambiance,...) sur mon ampli qui n'a aucun correcteur de tonalité ni loudness, quand la source est trop linéaire. Il répond à mes attentes.
PHILIPPE D.
pre tc 10
preampli recu aujourdui essai dans la journee tres bien mais moins bon les correcteurs en service dommage mais execellent pour le prix
Peter H.
Be careful, dangerous
Protection Earth is only on the Backplate...perhaps. You can measure it on your own. Only a drilled cable behind the cinchconnection. That is not the European standard. I have changed this. I drilled a hole, set a screw and a cable lug under the board, right under the power connector. Had to filing a little bit into the board...
I know...no more warranty...ok..but safe. EMV-Safe ? dont know...
The Sound is great...
Xavier B.
Retour après quelques mois d'utilisation
Preamp très efficace pour le prix, le schéma électronique est simple et efficace, pour à peine quelques dizaines d'euros j'ai recapé l'ensemble avec de bon composants, la métamorphose est impressionnante on gagne de manière très importante en précision, donc au final très satisfait surtout pour les possibilités de tweking de l'objet sans arrière pensées.
Emmanuel D.
Bon rapport qualité-prix
Il s'agit d'un petit pré-ampli de fabrication chinoise qu'on peut trouver sous d'autres marques. Le rapport qualité prix est bon. En particulier c'est appréciable d'avoir le transformateur de tension intégré, ce qui n'est pas toujours le cas sur les petits pré-amplis de ce type. La finition est correcte (un peu "cheap"...)
Xavier B.
Excellent Rapport qualité prix
Petit préamp qui fait bien le job, pas un souffle.
Meilleurs en mode sans correction, notamment dans le registre des aigus qui dans mon cas sont bien meilleurs sans la correction, même potar à fond.
Pour le prix excellent, manque peut être un peu de définition mais à 54€ difficile de faire mieux .
Martial B.
AUDIOPHONICS PRE-TC10 Préamplificateur avec Contrôle de Tonalité.
Excellent article, très bon rapport qualité / prix. A recommander pour de petites installations ou pour disposer d'un appareil pour essayer ou étalonner un bloc de puissance.
Utilisation préférée en mode direct (sans utiliser les correcteurs de tonalité).
A recommander !
Bertrand C.
préampli qui tient la route.
En général, les amplificateurs casques ne sont pas équipés de correcteurs de tonalité: c'est une erreur. Certes la bande passante de ces amplificateurs est réputée linéaire, mais la bande passante des oreilles de l'auditeur, elle, ne l'est pas, mais alors pas du tout !
Ce petit préamplificateur permet de corriger partiellement les défauts
de nos chères oreilles tout particulièrement dans le registre aigu et apporte également une meilleure dynamique. Il n'apporte aucun souffle.
Sa construction est sérieuse et le prix très raisonnable.
Jacques C.
Un petit bijou
Très bon rapport qualité/prix. Pour ma part, idéal pour piloter ma paire de QUAD II (dépourvus de volume et tonalités) ainsi que mes deux Dynavox vr80 qui ne possèdent pas de réglages graves/aigus. Pleinement conquis également par la possibilité de bypasser la correction, pour apprécier le rendement des tubes ou des enceintes. Bravo !
Roland S.
pour audio télé philips
Génial, associé à l'ampli FX AUDIO M160E et l'extracteur HDMI ARC vers RCA model CYP DCT-25 avec deux enceintes bibliothèque CABASSE ANTIGUA 220, pas besoin d'investir dans un système barre de son à 500 ou 600 Euros.
RS
The Audiphonics PRE-TC10 is a preamplifier offering of course volume control, but especially a triple tone control.
