michel H.
Retrofit de 2 caissons de basses Kliosch
Suite à l'achat de 2 caissons Klipsch hs ,j'ai procédé à leur rétrofit après adaptation de la caisse, par ces hp...
Eric B.
Bon dac,un peut cher..
En remplacement d'un Do100 pro,il y a effectivement du mieux : on perçois plus de détails dans la musique,image stéréo...
Rafael G.
Just great
Bluetooth 5.0 Receiver Board QCC5125 LDAC aptX HD aptX Adaptive to I2S - reviews - There are 2 reviews.
Martin M.
USB Communication
Search for SJR-BTM525, this is the name of the blue module and find module pinout
To enable USB communication you need to solder "USB_DP" and "USB_DM" to your preferred connector and you must solder/connect "VCHG" to your power voltage, without this the USB is disabled.
I connected "VCHG" to +5V currently working but not sure, maybe you should use +3.3V
PLEASE REFER TO CHIP DATASHEET (not module) TO AVOID ANY DAMAGE!!!
No-one takes responsibility for how you modded this module ;)
Martin M.
Defaualt code is "0123"
lot of product here missing some useful description
This Bluetooth 5.0 receiver module is equipped with the new Qualcomm QCC5125 chip, which supports the high-quality transmission codecs LDAC and...
