Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
DAYTON AUDIO DMA105-PR Aluminium Passive Radiator 37.9Hz Ø10.2cm - reviews - There is 1 review.
Cernat G.
Average.
A bit expensive for what it does.
The specifications seem to match the passive radiator with one weight and the mounting screw added, not without any weights added as the manufacturer claims.
I did no professional measurements, though, just testing with a cheap calibration mic and comparing the results with winsd projections for the box size and driver.
The DMA105-PR of Dayton Audio is a passive radiator of 10.2cm in diameter. This is an excellent solution for a bass boost in smaller speakers. This...
