Gérard B.
Buffer Audio type YAQIN SD-CD3
Après des écoutes attentive et relaxante, pour bonifier votre source que ce soit un CD, une platine Vinyle ou un DAC Bluetooth...
Rafa P.
Great for inside speaker wiring
Awesome cable. I am also very satisfied with the service from Audiophonics.
Marco R.
THINKYA JA-310 CD
The player looks quite nice considered the price.
It connects via toslink to a pair of Klipsch "the fives" and audio...
Digitale Interface I2S vers SPDIF BNC WM8805 24bit 192kHz - reviews - There are 2 reviews.
Joris J.
Great sound quality
I2S to SPDIF without problems.
In my high quality set up, this board proved to be very good, feeded with Jung super regulator power supply.
Be aware that you need the MCLK connection of I2S (or buy a clock to solder on this board). On the board this is a seperately placed pin, labeled MCL.
Alexandr C.
it works well
It works, if you want to connect to rca SPDIF (not BNC) connect sign(-) from (spdif out) to ground of rca cable, sign(+) throught a 75 ohm resistor in series to central pin of RCA cable . (without resistor conection jumps random) try any value near 75 ohm, mine 100 ohm works well.
This WM8805 interface with DSP XilinX allows you to transform an I2S signal with MCLK to a classic SPDIF signal on a 75 Ohm BNC connector.
