Markus W.
Good quality
Patrick v.
Magnifiques !
Tom K.
DIY Box / Case Integrated Amplifier 100% Aluminium 361x274x85mm - reviews - There is 1 review.
F.J. d.
Execellent product, absolutely satisfied!
Always a guess when you order a casing. This one is very satisfactory! All components fit perfectly. The case was assembled without any effort.
One tip: Add exact drawings, having all dimensions makes it easier to add or adapt stuff. The end result will be even more perfect ;) I , for example, need to modify the top 'lid' to fit 3 transformers and two large KT120 tubes. Replacing the top lid with another plate is easiest but I need accurate dimension to get a good result without the inaccuracy of measuring it myself.
 (3)
