Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
DYNAVOX AMP-S PRO Audio Selector Switch for Speakers / Amplifiers Silver - reviews - There is 1 review.
Kresimir M.
Spaces between Speaker terminals too narrow
quick and easy to deploy this switch but in case you are using robust (e.g. standard) speaker cables you will face problems with connecting all cables on the very narrow distance between speaker terminals.
The Dynavox AMP-S Pro makes it quick and easy to switch between two amplifiers and two pairs of speakers, without having to make new connections....
