Cedric J.
Manque d 'info
Cette carte doit sûrement valoir le coup. Je ne le sais pas car l'opération de montage de la carte de régulation ainsi que...
Alexandru Ovidiu A.
Magic
Used for DIY 5V DC cable , supply of JCAT USB. This cable brings TONAL RICHNESS to the table. Musicality. Highly reccommended
Robert C.
PRE KHOZMO ACOUSTIC "Sublime et performant"
Complément à mon avis du 26/04/2025 :
J'avais oublié la télécommande elle aussi à la hauteur :
En alu et complète avec...
E1DA COSMOS GRADE A Balanced ADC ES9822Pro 32bit 384kHz - reviews - There is 1 review.
jf a.
Great product !
If you want to seriously get into measurement but you can not afford kilos of money, go buy it !
Be aware of the Zin, for small signal it starts around 600Ohm, but THD+N of 140dB is there !
With a really good osc (janascard dot cz, another great piece of hardware) I don't have any harmonic ! just noise floor around -140dBFS (with 16384 fft points).
only 2 minor concerns:
- I hate usb-C , it is not harsh enough...
- same for the jack if you want to convert amplifier outputs
So it's really a great product !
With the Cosmos, E1DA offers a high-end balanced ADC, whose analog-to-digital conversion stage is based on an ES9822Pro chip. It uses only high...
