Alexandru Ovidiu A.
Magic
Used for DIY 5V DC cable , supply of JCAT USB. This cable brings TONAL RICHNESS to the table. Musicality. Highly reccommended
Robert C.
PRE KHOZMO ACOUSTIC "Sublime et performant"
Complément à mon avis du 26/04/2025 :
J'avais oublié la télécommande elle aussi à la hauteur :
En alu et complète avec...
MARC S.
Épatant
Branchements simples, reconnaissance immédiate de l'appareil depuis un smartphone Androïd. Utilisé avec Qobuz, relié en...
Female 4 Poles Jack 2.5mm Socket Gold Plated - reviews - There is 1 review.
Roeland T.
Close to what I need
This is a Female Socket that provides 4 connections. A 2.5mm diameter Jack plug with 4 Poles (3 isolation rings) does fit in this socket, However, only 3 Poles of the Jack plug make contact: the Pole furthest from the tip does not connect to the gold plated pin as I had expected.
This 2.5mm female jack socket is ideal for PCB mounting and will allow you to add an efficient connectivity to a DIY project. Its contacts are gold...
