Cyrille S.
Bon transport
Stian L.
A very good and powerful amp
Paul C.
D'une remarquable qualité
FOUNTEK NEO CD 3.5H Speaker Driver Ribbon Tweeter 12W 7 Ohm 95dB 1100Hz - 30kHz 9x60mm - reviews - There are 2 reviews.
Juan T.
Incredible tweeters
These are my main tweeters and are Incredible.
Super clean, light, musical, realistic. Impresive.
Will never use dome tweeters again. Its ultra low mass moving ribbon must make the difference.
Be sure the crossover is well designed and cuts at least at 3,5Khz, 3rd order.
Serge D.
Sergio
Excellent et conforme à sa description.Beaucoup de précision dans les aiguës au plus fort de sa directivité . Finesse et naturel , peu de distorsions . Une bonne approche bon marché des modèles à ruban professionnels.
Fountek innovates in the field of ribbon loudspeakers by adding a roof. The combination of these two technologies allows high frequencies to be...
