Markus W.
Good quality
Patrick v.
Magnifiques !
Tom K.
FURUTECH FP-209-10 (G) Spade Plug Rhodium Plated Pur Copper Ø4mm (Set x10) - reviews - There are 2 reviews.
Rene C.
Best buy
The fork is very solid, you can´t climp it to a cable with normal tongs !
You have to have access to and use a screw- device - wrench.
Only the final finish can be done with strong tongs !
Otherwise it is fine product, that sounds great !
Grzegorz B.
Very good quality product
I use them after crimp on cables for mount cables in power plug with rodium coatings. You have to use carefully, because the FP-209 are long and you can have about 0,5 cm of free cable (with inner isolation) to mount them in Furutech IEC power plugs. With longer free cable you can't holding whole cable in plug jaws. There limitation is only for IEC, for Schuko you have more space in power plug.
 (4)
