Jean-Claude F.
Très bon câble HP
Acheté en remplacement d'un câble Mogami 3103 pour bénéficier du bi-câblage. Ce sont les mêmes conducteurs donc j'ai...
Jean-Claude F.
Très bien
Contrepointes de bonne qualité pour un prix raisonable
Yvain C.
Mes fostex fe 208ez ce sont mises à bouger instantanément après l’installation du câble, des gravés en plus .
J’ai hâte de la...
GENALEX GOLD LION Rectifier Tube GZ34 / U77 / 5AR4 (Unit) - reviews - There are 5 reviews.
Francisco B.
Excelent service
Exactly as expected, which is exactly as anounced by Audiophonics.
Valuable supplier for audio and components.
Thank U!
jean-luc s.
bonne surprise
le remplacement de ces tube sur mon DAC PRIMALUNA m'apporte profondeur et élargissement de la scène sonore.ce petit plus m'immerge encore plus dans la musique.les attaques de note sont plus franches,bon choix.
Vladimir p.
Rectifier Gold Lion GZ34
Got this particular order the very next day (!) though the distance was few thousend km !!! Not only I did not expect delivarance this fast but I could never imaging this would be possible. Bravo, Audiophonics!
About rectifier GL GZ34 for my Muzi x7... It was very good right from the box - good separation, much more to hear in the Mids, good bass but Highs just a little rolled off. I knew that rectifiers need about 50hrs of burn in and after few days of use - voila! - Highs are comme il faut! My x7 never sounded better, and I have not even tried to roll power tubes yet (KT88)! But the most remarkable thing about GL GZ34 is that it is very musical: it takes notessounds and makes of them music. Love it! Can't wait to see what Mullard GZ34 will do (aph.fr has just shipped it to me).
So now I have 3 different very dicent rectifires to use - stock Muzi (very "tasty" sounding, slightly coloured but not too much), GL GZ34 and Mullard GZ34 (which is on its way home).
And thnx to aph.fr for excelent service, if I need something that they have I certanly will order from them. thnx.
Frederic G.
Tube GZ 34
Remplace avantageusement une valvo
eric m.
Indéniable amélioration.
Ce tube redresseur Genalex-Gold Lion GZ 34 est venu remplacer mon GZ 34 SOVTEK qui déjà fonctionne très très bien sur mon Ampli.SE. Mais par curiosité et sachant que ces 2 tubes sont physiquement identiques, Je voulais entendre une différence...........
Pour le coup la je suis fixé.....ce Tube redresseur Genalex apporte une scène sonore beaucoup plus ample, avec des instruments qui sembles plus réels, vraiment une nette amélioration à l'écoute.
En conclusion; très satisfais de cet achat, et du service Audiophonics.
This Genalex Gold Lion GZ34 / U77 tube is a rectifier tube, ideal for replacing a defective equivalent model.
