Gérard B.
Buffer Audio type YAQIN SD-CD3
Après des écoutes attentive et relaxante, pour bonifier votre source que ce soit un CD, une platine Vinyle ou un DAC Bluetooth...
Rafa P.
Great for inside speaker wiring
Awesome cable. I am also very satisfied with the service from Audiophonics.
Marco R.
THINKYA JA-310 CD
The player looks quite nice considered the price.
It connects via toslink to a pair of Klipsch "the fives" and audio...
GUSTARD P26 Discrete Class A Balanced preamplifier XLR RCA Black - reviews - There are 10 reviews.
Rajiv J.
Good preamp for the Gustard R26 DAC
I was looking for a preamp for my Gustard R26 dac, and was torn between the H26 and P26.
I chose the P26 preamp based on some (really helpful) advice from the Gustard support. The choice was driven by the following aspects:
1) I did not need the headphone amp, just a pure preamplifier.
2) I have swapped the LME49860 op amps on the P26 with Sparkos Labs SS2590. The Sparkos pair cost me 250 Euros, which took the P26 to a whole new sound level, that is hard to describe. The LME49720 op amps on the H26 are also on swappable DIP8 switches. However it has capacitors mounted very close to the Op-amps, and the Sparkos OpAmps are big and need space (LxB is 1.1 x 1.1 inch, or 2.8 x 2.8 cm). Gustard was kind enough to send me close up measurements that helped me conclude that the op amp swap would be tricky, or just not possible.
3) The P26 allows you to adjust gain between 0 to +6dB both in the input and output stage, which helps to harmonise and match with components on both ends. The H26 only has +6dB gain option at the output side.
4) Gustard support responded to my question of how both would compare in pre-amp mode with the following reply, I quote: "The P26 is a good choice for a preamp only. The P26 and H26 preamplifiers have different styles, the H26 is tuned a little softer while the P26 is a little clearer & transparent."
All in all, a good choice, as I said..
 (3)
LAURENT G.
Au bout de 4 mois d'utilisation
Les premières impressions positives se confirment. La transparence de la restitution et la séparation des canaux sont tout à fait remarquables. Les réglages de gains possibles 0, 6 ou 12 dB permettent une grande souplesse d'utilisation en fonction de la nature des sources et/ou des enregistrements. L'association avec un HPA-S 400ET forme un duo dont les performances sonores sont cohérentes avec les mesures et essais techniques que l'on peut trouver sur internet. Cependant, il ne faut pas s'attendre à une restitution systématiquement somptueuse ou flatteuse : les enregistrements sont reproduits sans fard. Les timbres peuvent perdre le charme que peut présenter un ampli à tubes (je le sais pour en avoir un). Mais le gain en terme de précision de la restitution est si flagrant qu'il est impossible de masquer les différences entre les sources numériques (en prenant le format CD comme référence) et les sources analogiques (radio ou phono). Les 30 à 40 dB de transparence supplémentaire qu'offre une source numérique ressort immédiatement.
Laurent G.
 (3)
Jean-Pierre D.
Un composant intéressant pour un ampli de puissance
Je recherchais pour exploiter mon ampli Purifi Audiophonics HP 400 ce type de préamplificateur, il s'avère idéal car j'ai à driver des enceintes Signature Delta de Triangle (vu sa caractéristique classe A). Les Triangle sont exigeantes en électronique car ce son des enceintes extraverties très chantantes.
Le résultat est très bon pour un prix d'achat pas dans ce que l'on trouve habituellement sur le marché. Pour l'instant, j'ai connecté en XLR avec l'ampli de puissance en XLR et en RCA avec le lecteur réseau (un Eversolo DMP A6), j'envisage plus tard un XLR pour cette dernière interconnexion. La restitution est pleine, détaillée et neutre avec un joli son jamais agressif, c'est une prouesse avec les Triangle. Je recommande pour ceux qui recherchent ce type de préamplificateur.
LAURENT G.
Premières impressions
Preampli transparent et suffisamment puissant pour l'utiliser avec l'HPA -S400ET que j'ai du régler sur 20 db de gain pour pouvoir garder un réglage fin du volume.
Utilisé en sortie XLR, la possibilité de rajouter du gain en sortie est bienvenue pour une source phono qui gagne un peu de relief.
Ce appareil ne semble avoir aucune signature sonore et n''apporte donc aucune coloration particulière au son. Belle qualité de construction apparente et plutôt lourd pour la taille.
L'ayant reçu très récemment, il est trop tôt pour lui donner une note, notamment sur la fiabilité.
Mode d'emploi en français téléchargeable appréciable, mais ce serait mieux s'il était systématiquement joint avec l'appareil.
L.G.
 (3)
Philippe P.
SUPERBE!
Un excellent préampli, pour une écoute très naturelle.
GUSTARD surprend encore avec ce produit de haute volée pour un prix raisonnable. Cerise sur le gâteau, l'utilisation de ce bijou est extrèment conviviale : gain adaptable, volume télécommandé et ajusté par relais au cliqueti bien sympathique! Avec une sureté de fonctionnement qui impose le respect. Merci à Audiophonics, qui propose des produits de haut niveau, mais encore abordables, et qu'on ne trouve, nulle part ailleurs.
Philippe M.
Que du plaisir
Aération, précision et profondeur c'est ce que l'on gagne avec cet appareil. Les vinyles revivent avec un préampli phono Micromega.
Bonne complicité avec le Dac X16 de la même marque et la connexion XLR. Le volume peut être réglé très finement grâce à l'affichage.
BEATRIZ H.
Paul
I forgot to mention that I use it with a Denafrips Ares 2 DAC . Regards Paul
BEATRIZ H.
Paul
Hi there , a very good sounding preamp for a reasanable amount of money and fully balanced . This store is a present from heaven for me . Thank you for your patience with me . Regards Paul
Alain L.
une perle rare , un RQP HORS NORMES.
J'ai osé placer ce préampli au coeur d'un système dont les éléments valent trois fois son prix. Et bien quelle surprise de l'écouter chanter au même niveau. De par sa transparence , sa neutralité et son silence de fonctionnement, ce préampli fait curieusement penser à un modèle passif.
l'image est large, il y a de l'air entre les pupitres. Il faut cependant bien lui laisser une période de "réveil" ou rôdage comme vous l'entendez. Il chauffe beaucoup pour un préampli, bien le laisser aéré est quasi indispensable. lui laisser le temps d'arriver à pleine temporisation sera également un plus musical. En conclusion : une petite merveille INCONTOURNABLE pour son prix.
 (3)
Daniel L.
Superbe
Très très bon préamp !
Droit, dynamique, silencieux. Si vous recherchez un modèle pour réchauffer un peu votre son, celui-ci n'est pas fait pour vous.
Si, en revanche, vous voulez de la dynamique, de la transparence, du silence et du gain, alors oui, considérez le P26 comme un excellent choix.
En entrée Pré In de mon PSE 300ß, le mariage est superbe !
De plus, il est beau, bien fini, de taille intermédiaire, la réception IR très réactive, l'écran OLED jamais éblouissant.
Bref, superbe pour un prix très abordable.
Gustard P26 is an elaborate preamplifier / volume controller / strain selector (3 inputs). It will delight audiophiles looking for a fully balanced...
