EMMANOUIL B.
The Best Copper Wire in Earth For Hi-Fi
Don't be fooled by the the title "Wiring Cable" !! Use this wire in power and speakers cables. For power cable...
patrick a.
Relié en optique au drive et en coaxial au steamer,
ce joli petit dac offre un son chaud et musical, sans aucune agressivité.
Francois g.
Un très bon cable
Cable Utilisé pour relier un IPad avec Quobuz à mon dac : Cette solution simpliste fonctionne tres qualitativement et me...
HDMI I2S LVDS to I2S Input Module HDMI I2S LVDS to I2S Output - reviews - There is 1 review.
Horia C.
It works O.K. but...
...But you will have to cut the solder between the ''H'' and the center point at the power-Supply section and solder the ''A'' point to the center point. This is necessary to use this board Power-supply which will deliver the 3.3 V DC to the ICs. Initially, using the ''H'' to center point connection you will use the HDMI cable voltage provided by the Source, in my case it didn't work because the Source provided only 1 V DC. I hope it helps. Enjoy!
