Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
HICON Tricone MKII - Cable XLR-3 Male / RCA Male 1.0m (Unit) - reviews - There are 2 reviews.
Patrik L.
The cable is missing a separate conductor between RCA sleeve and XLR pin 3 to avoid ground hum.
David T.
parfait
Câble au rapport qualité prix excellent!
