Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
IAN CANADA FIFOPI Q2 ULTIMATE Reclocker Module FIFO PCM 32bit 768kHz DSD1024 DoP - reviews - There are 2 reviews.
Charles M.
Great idea but no support
I purchased this after reading Ian's posts demonstrating that it worked with Buffalo III DAC. I have not been able to get these two boards to work together. After reaching out for support over a period of weeks there have been some replies but none simply describing how to configure and connect these two devices. Great idea but of no use without support.
Thomas v.
Perfect way to transport your audio onto your dac!
This module is the absolute best way to transfer your audio from your Raspberry Pi (or other single board computer). This modules enables you to upgrade the very important clocks (for instance with ACCULUSION clocks). The module is extendable with other products from Ian Canada or can transpass the audio onto your dac via I2S.
 (3)
The  FiFoPi Ultimate  from  Ian Canada  was designed to significantly reduce the jitter of the digital...
