Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
IEC C14 Plug with ON-OFF Toggle Switch and Fuse Gold Plated Pure Copper 250V 10A - reviews - There is 1 review.
Cedric J.
Oui, mais....
Adapté pour une épaisseur maxi de 1,5 mm. Sinon, bonne connections et qualitatif.
This IEC C14 socket is ideal for integration into a DIY device as a power connector.  The socket incorporates an ON/OFF toggle switch for...
