Patrick W.
Très bon produit et envoi express
Deuxième achat de ces tubes en même temps qu'un tube redresseur 5U4GB, très bons produits et surtout envoi très rapide et...
Leszek W.
Solid build quality and a significant improvement in the sound of the powered device. I highly recommend it, especially if you...
Leszek W.
IFI AUDIO IDEFENDER+ Anti Ground Loop Filter Male USB-A to Female USB-A - reviews - There are 2 reviews.
Todor S.
Great device!
I have a Chinese DAC that is powered by USB, but there is no noise filtering from the current, so I needed to feed it with clean electrical signal. Ifi Defender+ does a perfect job for this - I'm using a smartphone power supply now, but I'm thinking of buying an Allo Nirvana to further improve the sound quality.
Jérôme L.
Ne change rien sur ma config
Toujours autant de bruits parasites même avec le idefender+ :/
The iFi Audio iDefender+ allows you to cancel noise originating from a ground loop in your audio system. Indeed, the inevitable use of several...
