Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
LHY AUDIO Triple Linear Power Supply Module LT1963A 5V / +/-5V - reviews - There is 1 review.
M A.
Build quality is good and easy to adjust.
It would be even better if it could deliver higher amps.
all in all a perfect product.
This LHY Audio triple linear power supply module offers a very nice design quality, using three LDO voltage regulators LT1963A to provide a clean...
