Markus W.
Good quality
Patrick v.
Magnifiques !
Tom K.
Linear Power Supply board MJE15034G Low noise 4.8V à 24V 2A - reviews - There are 7 reviews.
Adam S.
super regulator
very nice regulator based on the super regulator schematics
with a better opamp like lm6172 it delivers much better performance,i also use it with 2sc5200 instead og the mje15034g transistor for better power dispersion,truly a top end regulator
Lukas B.
There is a washer in the regulator heatsink, that is not capable of taking the heat. Might as well remove it before it starts smoking, it's capable of transporting the heat without being screwed to the heatsink.
Sylvain B.
Bien s'assurer sur voltage de sortie requise
Delivre 3 rangees de sorties seulement et tout voltage entre chacune des 3 rangees est indisponible, on peut utiliser un second regulateur Lm317 en serie comme solution mais l'amperage est alors limitee @ 1.5A, et aussi porter attention une difference minimale de 1.5v pour un bon fontionnement.
Joris J.
Excellent
Gave my huge improvement of sound quality of DAC and another one in sound quality op raspberry SPIDF HAT, both in combination with a 30W R-core transformer.
István B.
István B.
Excellent
David B.
Bon produit
Belle qualité, très pratique, composants de bonne facture.
William l.
nice power supply
Hello, with 10W maximimum power consumption connected to this board it unfortunately gets too hot, need more and bigger heatsink!
But nice product!
This is a very high quality regulated power supply with a very low ripple, high precision semi discrete with a double layer circuit.
