Giovanni B.
Purchase
Dear Sir, my package will arrive as soon as everything is available, or will you ship what is already in stock first? Let me...
Juha K.
Excellent
This amplifier could be described as very versatile for different music genres. Purifi has never disappointed my own ears. This...
Eric H.
Fiches RCA de qualités
Très bonnes prises RCA de très bonnes qualités.
Le seul bémol c’est la soudure de la masse sur le corps qui n’est pas...
LJM GC LM3886TF Stereo Amplifier Class AB 2x68W  - reviews - There are 4 reviews.
Nikolaos R.
Very reliable for its price. The sound is clear and I was impressed with the channel separation. Of course, no comparison should be made with expensive amplifiers.
Pavel Z.
Requires modifications
Power decoupling in this amplifier is poor: it is only bulk capacitors and two 0,1 uF film capacitors. The film capacitors are far from chip terminals so they don't really decouple anything and at the same time are close to the bulk capacitors that are low-ESR, this results in a strong antiresonance effect. You'll need at least to remove the film capacitors and then add something like SMD ceramics at chip terminals on the board back side and also add small electrolytic capacitors. See neurochrome SPICE model for an example - although I cannot recommend using solid polymer capacitors, they sounded weird here.
Also consider shorting the capacitors in feedback loop.
Sébastien S.
Mauvais!
Sonorité assez dure et distord complètement sur les faibles signaux musicaux!
A éviter.
 (4)
Benoit G.
pas mal
Petit module qui fait bien sont boulot
Facilité de mise en oeuvre
Rendu sonore honnête
Ne pas oublié le radiateur adapté
