Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
LOXJIE D60 DAC Headphone Amplifier ES9039MSPRO Bluetooth 5.1 32bit 768kHz DSD512 MQA-CD Black - reviews - There is 1 review.
Andrzej B.
Loxjie D60 - excellent DAC/Headphone Amp
Very transparent and neutrally sounding DAC. I use it with headphones Hi-Fi Man Sundara Closed Back edition via balanced connection and as a source I use WiiM Mini connected via Optical link. I am very satisfied with the sound.
As regards funcionality it has all important digital inputs including I2S and outputs (including headphone balanced XLR) and bluetooth connection with high quality codecs (LDAC and Aptx HD). The only drawback I noticed is very poor stability of bluetooth connection when using highest bit rate of LDAC codec (900 kbs). The are frequent drop outs so it needs to be switched to lower bit rate (606 kbs) or use different audio codec like AptX which works fine. Everything else works perfectly.
It is also very good for the price. I can truly recommend it.
The ordering, payment and delivery process at Audiophonics was perfect. I was really satisfied.
With its D60 DAC / headphone amplifier, Loxjie offers a modern, high-performance device, carefully designed and equipped with audiophile...
