Jean-Claude F.
Très bon câble HP
Acheté en remplacement d'un câble Mogami 3103 pour bénéficier du bi-câblage. Ce sont les mêmes conducteurs donc j'ai...
Jean-Claude F.
Très bien
Contrepointes de bonne qualité pour un prix raisonable
Yvain C.
Mes fostex fe 208ez ce sont mises à bouger instantanément après l’installation du câble, des gravés en plus .
J’ai hâte de la...
LV1084 20V / 5A Dual Controlled Linear Power Supply Module - reviews - There are 3 reviews.
Gerti C.
Funziona...ma!
Di scarsa qualità dei materiali. Led rotto..componenti piegati..saldature a limite della decenza. Anche se funziona la V. in uscita e sempre ballerina.
(Peccato non si possono postare delle foto)
Rudolphe D.
Description à revoir
Pas possible de sortie des tensions inférieurs à 5vdc contrairement à ce que vous indiquez
Marco P.
DIfferent from the one illustrated
Once received the item, it seems "old" and a bit rusty and with different components than the ones in the website photos. A 10k resistance was cracked (not a grat problem, substituted). The most great difference (or problem) is in the capacitors bank. the PCB reports "10000uF", but in web photo we have 2200 uF x4 x Channel (quite near) and mounted I founded 1500 uF x4 xChannel, which is quite half than declared. Volt for capacitor is also different (35V instead of the illustrated 25V and that could be better). Also diodes are not the illustrated one (they are Motorola MBR1645 in a TO220 package).
I know these items are not produced by Audiphonic, but a more deep control of conformity may be in result of a better service. It's functional but I'm not so satisfacted. Sufficient but not more.
Marco
 (8)
