Giovanni B.
Purchase
Dear Sir, my package will arrive as soon as everything is available, or will you ship what is already in stock first? Let me...
Juha K.
Excellent
This amplifier could be described as very versatile for different music genres. Purifi has never disappointed my own ears. This...
Eric H.
Fiches RCA de qualités
Très bonnes prises RCA de très bonnes qualités.
Le seul bémol c’est la soudure de la masse sur le corps qui n’est pas...
NEOTECH NES-3003 MK2 Speaker Cable UP-OCC Copper Silver Plated 4x1.3mm² Ø19mm - reviews - There are 6 reviews.
Dominique M.
Bi amplification
Difficile à monter,pas d’indications de montage,faut-il garder les fils argentés ou les supprimer comme le montre une vidéo you tube?dans l’expectative je l’ai les enroulées autour du cuivre.
Des précisions de montage de la part d’ audiophonics seraient bienvenus au prix de ce câble.
Ceci dit je ne regrette pas cet achat,le son est vraiment bon sur tous les critères.
Un avis de quelqu’un en ayant aussi l’expérience en France peut être ?
Tjalling B.
Difficult DIY but worth it
Not the easiest to terminate properly, but well worth the effort.
Very neutral speaker cable with good soundstage and placement of instrument and voices.
I’m using it single wire; red + white and black + blue.
The shield of the individual wires (silverplated copper) is twisted together with the copper.
Well worth the money
Salvatore R.
exceptional cables
exceptional cable, remarkable 3D image, the instruments appear more in focus and great musicality.
Excellent audiophonic in very fast shipping.
Filip M.
Didn't expect that much of a difference. Simply amazing speaker cable, makes listening a lot more fun. It would be a good idea to get some pliers along with it, peeling the wires was a pain.
Yngve I.
Superb
If you have the means, buy !!!
Vladimir S.
Dead quiet with thrilling transparency
The first thing which I noticed having installed the cable between my Plinius 9200 integrated and Dynaudio Contour 20 was the absence of any noise between the notes. The location of instruments became absolutely precise, timbres more natural and rounded, more life-like and less digital with my all digital sources. It is only the first hours of listening but it is clear that this cable is an improvement over cables of equal or even higher price which I own. You only need to remember that the cable is heavy and thick which gives less flexibility at installation. It probably will lead to a higher length or dedicated supports. I used the cable single-wired having followed a mounting advice of an alternative supplier. It was a bit tricky but the result was amazing.
 (5)
The Neotech NES 3003 MKII loudspeaker cable has a special hybrid topology to reduce the effects of capacitance and inductance. Composed of OCC and...
