Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
Power Cable Jack DC 5.5 / 2.5mm 0.5m - reviews - There is 1 review.
Renzo L.
Very Good
Doesn't look cheap at all and the 5.5/2.5 plugs go in cleanly and make stable electrical contact.
This power supply cable allows you to connect devices with DC 5.5/2.5mm jack inputs to compatible regulated linear power supplies.
