Cyrille S.
Bon transport
Stian L.
A very good and powerful amp
Paul C.
D'une remarquable qualité
Rubber Damping Feet Ø16x8mm Transparent (Set x4) - reviews - There are 3 reviews.
Ioannis K.
Excellent for small components
Very good for small stuf.I am using them in my VMV D1SE DAC replacing the annoying factory spikes.It does the job.
Michel M.
Pieds pas chers et efficaces
Je recommande ces pieds, en particulier sous des lecteurs cd, lesquels peuvent parfois apparaître agressifs avec des pointes.
Ces pieds sont trés efficaces alors...
Karl R.
Do what they're supposed to.
Not much to say. They're firm plastic feet that are easily glued to your device of choice.
These shock absorbing rubber feet with a diameter of 16mm and a height of 8mm are simply glued under your devices using the double-sided 3M...
