Raymond M.
Ecouteurs oui, câble non
Les écouteurs sont super (c'est du planar top niveau) mais le câble est à jeter illico... il étouffe complètement le son,...
Antonio D.
Excellent
Super amplificateur, très neutre, dynamique enorme, beaucoup de réalisme et transparence, sans jamais fatiguer a l´ écoute....
Marcel O.
Gustard H26 highly recommended
I love the product. Outstanding built quality. The audio quality is phenomenal. I don’t know if it can actually get any better....
SMPS300RS Module d'Alimentation à Découpage 300W / 24V - reviews - There are 9 reviews.
Thibaut L.
J'ai commandé une 36 v pas une 24 v
Iulian M.
The best 24v smps I have ever owned.
60-80mV is NOT ultra low noise/ripple but with more filtering i could get it to 2-3mV and that is the best result i ever had with a smps.
Powering a Burson Funk, it really makes a difference. It's like the Burson SuperCharger but without the background noise and without the exagerated price. A minor issue is the input filtering choke that is flapping around and it really needs a bit of glue.
Elsa A.
Excellent module SMPS300RS
Faibles parasites EMI, faible encombrement, si la fiabilité est comparable aux SMPS 500 et 600 on est proche de l'optimum
GEORGIOS N.
Makes a big difference for DIY Boards
I bought this for an ARYLIC UP2STREAM AMP 2.1 Amplifier Module diy project. Previously I had the board connected to a 19V 4.5A brick from an old PC and the sound was very thin for a satisfactory music experience. Once I connected the SMPS300RS wow! Robust sound levels with no sweat from this power supply, it doesn't even get hot, not at all. No hum noise whatsoever, everything sounds impeccable and drives effortlessly any small diy amplifier board. Highly recommended, the 4 stars due to the build quality of the of the copper winding of coils which is not at par with the rest of the board.
Francis L.
Excellent pour class D
Couplé à un SA300, à une paire de Klipsch RP et un caisson, la différence dans le spectre des basses fréquences est flagrante, reste trop cher pour une alim mais l'effet wahou est bien réel.
Chebl D.
SMPS300RS Module
I am still wrapping myself around using it.The fact that it comes with no manual does not help. I will come back to you later to give you my opinion.
Jacques S.
Alimentation à décuopage pour FDA alientek D8
Alimentation SMPS 24 V montée dans un boiter aluminium, câblée avec fils Néotch multibrins 1,3
mm2+ connecteur Elecaudio DC et pour le secteur un câble MIT en direct modifié avec une prise Viborg VE 501cuivre pur + inter aviation, L'alimentation sert à alimenter un FDA Alientek D8 .
Le gain en restitution est très supérieur à à l'alimentation d'origine , avec un parfait silence de fonctionnement (message parfaitement propre et non pollué) : Augmentation de la transparence avec encore plus de détails , meilleur séparation des pupitres ( beaucoup d'air circule entre les instruments),temps de monté accru au niveau du FDA qui génère de très bonnes attaques ainsi que de belles extinctions de notes sont au rendez-vous, le tout accompagné d'une justesse des timbres avec fluidité et dynamique. Alimentation vivement recommandée pour tout FDA et n'ayant rien à envier à une alimentation linéaire plus coûteuse et gourmande en énergie.
Une bonne alimentation sublime l'alientek D8 déjà excellent en mode flat.
Encore merci à Audiophonics pour les produits proposés et le service de qualité.
Cordialement et musicalement Jacques.
François L.
EXCELLENTE ALIM pour FDA
achetée pour l'installer sur un smsl AD18, je pensais avoir un léger gain sur la tenue du grave, mais là je suis bluffé, une limpidité,,une aération, un niveau de détails dans la restitution et un grave parfaitement maitrisé.
J'utilise le combo AD18+SMPS300RS aussi bien sur des tannoy ARUNDEL 38cm coax que sur des JBL L96 et les conclusions sont les mêmes.
ALAIN P.
J'ai acheté cette alim pour alimenter 2 platines de TDA7294. Je craignais principalement qu'elle fasse un petit bruit résiduel de secteur ou de 100 Hz dans les HP. Eh bien non ! Rien ! même pas un fourmillement, NADA !!!! (rien en espagnol !!)
Cette 300w a l'air de rigolé de ces 2 TDA 7294 alimentés en même temps. Le son ? eh bien on sent qu'elle a la pêche la tigresse ! A l'oscillo je monte à l'écrétage crête à crête à 72 volts soit 79 w sur charge résistive de 8 ohms en régime sinusoïdale et en régime carré je sature sans perte de tension parfaitement stable. Vous me direz qu'avec 300 w pour 2 amp de 80 w avec un rendement de 75¨%, il reste encore de la marge !!!..
La fabrication est professionnelle, il n'y a rien à redire. Cette alim est donc stabilisée et régulée, pesant quelques grammes et prenant 10 cmx10 cm de place dans un coffret. C'est mieux que 5 Kg de transfo + pont+capa et le tout non régulé.
Je voulais essayer ce que donne une alim à découpage pour de l'audio (probleme de la HF dûe au découpage...) eh bien je suis rassuré, remarquez, les alim de PC sont bien du même type et il n'y a pas de problème....
Derniers points à préciser, je l'ai donc pris en version +ou- 24 volts, et même en régime carré à saturation des amplis, elle ne chauffe pas.
Je suis très satisfait de cette alim qui répond parfaitement à l'objectif fixé à savoir : prix par rapport à version transfo à même puissance, pas de ronflement, ampli sans le lourd poids des transfo, gain de place dans le coffret.
