Jeffery F.
Great product!
Received it today after ordering only 3 days ago! Sound is awesome (A/B with a Node model prior to the current one with a...
Bastien S.
Bien mais pas fantastique.
J'ai acheté ce câble d'occasion sur LBC, mais vu l'emballage, il avait été acheté ici.
Avant lui j'avais...
Olivier B.
SMSL SANSKRIT 10Th MKII DAC 32bit / 768kHz DSD512 USB XMOS AK4493 Black - reviews - There are 18 reviews.
Noel C.
Retours apres longues ecoutes et plusieurs jours
Je reviens sur mon avis précédent , après avoir insisté à l'écoute sur plusieurs jours de ce DAC entre preampli classe A et le lecteur CD Chanling le son s'est vraiment amélioré, je ne saurais dire pourquoi, mais c'est un fait.
Très heureux finalement de cet achat.
Noel C.
Moyennement satisfait
Sur mon système, le DAC intégré au lecteur CD Shanling Tempo eC1B me donne plus de satisfaction auditive que ce DAC.
Essayé tous les filtres sans succès.
Cependant l'audition de chacun est différente ainsi que le système hifi.
Il n'y a qu'en comparant que l'on trouve son bonheur.
kg s.
Surprisingly good
It sounded too good when reading the specs and all comments around the web, but I couldn´t resist although I already have a good dac from Nuforce. The main reason was to be able to play DSD-files. From start I was convinced that it did sound as good as my old dac (did cost about ten times the price of Sanskrit 10th, several years ago) and it does play all DSD up to 256 without problems. Playing 512 is not possible yet, but it is a MacOS issue. And it does it great! I had a few questions and got prompt answers from audiophonics, cudos! I did change the tiny USB-cable to something mor sturdy and a bit longer. I use external power although it worked well without it. I made a blind-test to the Nuforce DAC-9 and it was impossible to hear any difference playing 24/192 or lower resolutions (DAC-9 doesn´t handle DSD). Really great sound for peanuts!
Do I recommend it? Yes
Do I recommend Audiophonics? Yes
Remi B.
Ce DAC a été associé aux amplis Atoll IN 30 et TAGA HTR-1000CD et aux enceintes Triangle Zerius 202.
J'ai acheté ce DAC par rapport aux avis et à sa distinction Quobuzissime: je m'attendais à mieux. Je l'ai comparé à un AUDIO GD NFB 15 de 2014 qui a également reçu la distinction de Quobuz. Certe, ce dernier était vendu 300 euros à l'époque, mais ces deux DACS ayant reçu la même distinction, je pensais qu'ils étaient assez proches en terme de résultat.
Il faut d'abord régler le son au maximum de mon lecteur ONKYO HF player pour avoir du son (volume du DAC au maximum), le son est beaucoup moins détaillé et naturel que sur mon AUDIO-GD.
En conclusion, j'en ai pour mon argent mais sans plus.
Etienne B.
Très bon DAC
DAC que j'utilise entre un raspberry et un ampli classe D (Allô Volt+D). Rempli parfaitement son office. Le son résultant (qui dépend bien sûr aussi de l'ampli et des enceintes Davis Acoustics Olympia One Master) est détaillé, précis. Les attaques (piano, clavecin ou percussions) sont très réalistes. Les timbres sont respectés et me paraissent très justes.
Les 3 entrées sont bien pratiques : le raspberry sur port USB, une télé sur port optique, un lecteur DVD sur port coaxial.
Seule la télécommande laisse à désirer : même en étant bien en face, ça ne marche pas à tous les coups... ce qui réduit le confort d'usage pour un rôle de réglage de volume du système.
Hervé C.
Rapport musicalité/prix imbattable !
Tout est dans le titre !
L'équilibre spectral est très bon, les timbres très réalistes. Il se sort très bien des passages complexes et chargés en informations. La dynamique (macro et micro) et le sens du rythme sont excellents. Foot tapping garanti !
A remplacé avantageusement un Musical Fidelity V90, très musical lui aussi, mais moins équilibré et fin.
Peut-être la scène sonore est elle un peu limitée entre les enceintes et en profondeur mais très précise et stable. Un léger manque de détail... Mais j'ai peut être aussi un peu de boulot d'optimisation sur le reste du système.
La télécommande semble fatiguer un peu vite et est assez directionnelle. Mais il faut dire que je change souvent le volume du DAC à cause du manque de progressivité du volume de mon ampli. Au passage, le volume du DAC est respectueux du signal.
Bref, on en a très largement pour son argent !
Merci encore à Audiophonics pour la qualité du service, conseils de David en particulier.
Serge H.
Dac smsl 4493
Acheté en remplacement dun dac Cambridge coûtant 3 fois son prix.
Ce DAC est incroyable même avec une simple alimentation de 5v.
Tout y est : detail, ampleur, douceur.
Merci Audiophonics . Continuez à nous donner des produits à bon rapport qualité prix.
Ali B.
excellent dac
Ce dac est une belle surprise,une qualité d'écoute audiophile,je recommande ce produit,
Ali
Gaetan g.
qualité de son parfaite mais ergonomie à revoir
Testé sur ampli rega brio / enceinte davis eva / source qobuz - On "entend" vraiment la difference avec ou sans dac mais je reproche une ergonomie qui est trop contraignante , les touches de la tele-commande ne fonctionnent pas bien, c'est un peu en mode "aléatoire" , c'est pas du tout agréable à utiliser. Par contre, res belle amélioration de la qualité audio avec le dac : plus de detail, espace de scene vraiment meilleur, le dac en lui meme est qualitatif
patrice f.
dac sanskrit 10th mkll
Très satisfait !
En réalité, je ne m'attendais pas à un aussi bon rendu !
Merci à David pour son conseil.
Patrick M.
Super lilliput dac!
Suite aux avis postés ici et aileurs je me suis laissé tenté par ce petit dac.En remplacement d'un behringer ultramatch pro de 2006.Ce que j'ai perdu en 24/96 je l'ai gagné et oh combien en homogénéité,en naturel,en timbres,en largeur de la bande passante, en précision et placement des interprétes .Large scéne stéreophonique ,effets de réverb(couleurs) et délais superbes,dynamique vrai sans agressivité.Son organique,analogique et qui a du poids sur mon systéme.Bref un petit dac au gros son!
Daniel L.
Super mais avec une faiblesse tout de même
Je ne vais répéter tout ce qui a déjà été écrit; c'est un super petit DAC, équilibré et performant.
Un (gros) défaut toutefois selon moi, l'utilisation incontournable de la télécommande ! J'ai donc copié les codes de l'allumage/extinction, le volume sur une universelle pour ne pas à avoir l'utiliser tout le temps.
Jose A.
A DAC star
This DAC is really good: the sound is transparent, with well-defined highs, superb human voices and mids; the bass is deep and puts the amplifier's capacity to the test. I have this DAC connected to the USB 3.0 port of a fanless i86 SBC computer (runing the Daphile music server & player) and they both consume a total of 6W.
Jean Noel B.
excellent à ce prix
Très bon rapport qualité prix , aucun souci de fonctionnement avec PC sous win 10, pas de problème avec télécommande , parfaitement satisfait.
Gestion de la commande et envoi très rapide, bravo a votre équipe.
Samuel L.
DAC Excellent pourquoi payez plus cher
DAC Excellent pourquoi payez plus cher et surtout ajouter l'alimentation régulée Audiophonics qui est excellente et fait très bien le job.
Super et supporte tous les formats actuels dsd, hi-res, mqa...
Rémy D.
Très très bien
Appareil très bien fini, compact, excellente sonorité, plans sonores bien découpés. Il comporte 6 filtres. Je l'alimente par un port usb de la télévision, et il garde, à l'allumage, l'état dans lequel il était à l'extinction précédente. Réglage du volume précis.
Seuls défauts : l'affichage bleu n'est pas assez lumineux, il faut s'approcher pour le voir correctement, et la notice n'est pas en français.
Sándor S.
Sounds wonderful! I absolutely recommend it!
Be advised that it'll only come with 1 micro USB cable, so better get another micro USB cable and an AC adapter (used for phones e.g.) for the power/aux. input! It is recommended to connect the aux. input USB to the AC adapter if it used for a PC.
Jean-Yves C.
Excellent DAC+ Volume Rapport qualité/prix excellent
Reçu il y a quelques jours, j'ai testé ce DAC sous toutes ses coutures avec des configurations très différentes:
Lecteur CD Denon en optique, BlueRay Samsung en coaxial, PC Asus en USB. En sortie, raccordement sur plusieurs amplis de puissance (Cairn, ampli tubes et transistors tous deux faits maison). Rien à dire, du bon son sur des Triangles haut de gamme.
Tests à l'oscillo impeccables.
Et en plus ce boitier n'est pas encombrant et peut se poser à plat ou sur le côté.
Je suis très satisfait.
This is the MKII version of SMSL Sanskrit 10th anniversary edition : an original and aesthetic device with extremely complete...
