Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
SOVTEK EL84SOV / 6BQ5 Tube Pentode (Matched Pair) - reviews - There is 1 review.
Jean Francois A.
Conforme
Conforme à mes attentes. Livraison rapide et colis bien protégé. Super !
The Sovtek EL84SOV/6BQ5 is a pentode tube with equipotential cathode, designed to amplify low frequency power in the output stages of HiFi audio...
