Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
TINYSINE AUDIO-B PLUS Bluetooth 4.0 Receiver Module - reviews - There is 1 review.
Diego D.
très bon produit
simple et conforme à la description. qualité audio appréciable
If you want to build a Bluetooth amplifier simply and stream your music from your smartphone, then the TinySine Bluetooth AudioB Plus receiver...
