Cyrille S.
Bon transport
Stian L.
A very good and powerful amp
Paul C.
D'une remarquable qualité
TOPPING D10 USB DAC 32bit/384kHz DSD 256 XMOS U208 ES9018K2M - reviews - There are 17 reviews.
Emanuele Davide Ludovico G.
I needed something to reproduce liquid music to my Revox system (a76, a77 & a78). I used an old asus vc60 with Daphile streaming music out of its 3.5mm jack. When this DAC arrived it changed my world! I am no audiophile and I lack in the correct vocabulary, so I'll say that its like watching a poster when you were used to look at a postcard. Everything sound bigger (not louder, but wider), sounds are more clear and distinguishable. To me it's a new listening experience. Very good product, I'm afraid I cannot listen to music without it from now on!
Helge V.
Topping D10 USB DAC
Have received this USB D10 DAC today, shipping was then delayed due to corona virus, but the wait can withstand one as long as waiting for an exciting product.
This is my first DAC, and based on what I've read and recommendations, it should be a good DAC to begin with.
The shipment was well packed, no hint of damage etc. So thank you for the deal.
With regards.
Jean-luc C.
Excellent remplaçant du AUDIOPHONICS U-Sabre USB DAC 24Bit/96kHz SA9023 / ES9023 TCXO
Possesseur du DAC Audiophonics U-Sabre mentionné dans le titre, je regrettais de ne pouvoir lire directement certains fichiers audio en 24/192 et des iso de DSD, j'ai donc opté pour ce nouveau dac. En première écoute en mode PCM, il me semble que le son est plus clair, aéré que ce soit sur du Flac 44.1/16 ou 24/96 avec des morceaux que je connais bien. Je me suis penché suer la possibilité de lecture en direct des DSD.
Il faut d'abord récupérer le driver ASIO Topping sur leur site :
http://www.tpdz.net/newsinfo/374859.html
Le fichier contient toute la procédure en anglais ainsi que les fichiers nécessaires (Driver ASIO, composants Foobar 2000)
Avec Foobar 2000 , les réglages sont :
File - Preferences - Output - ASIO : foo-dsd-asio
Double clic sur foo_dsd_asio pour l'accès aux réglages supplémentaires:
ASIO Driver : Topping USB Audio Driver
DSD Playback Method : ASIO native
DSD to DSD : None Fs DSD 128
PCM to DSD: SDM Type D Fs DSD 128
DSD/PCM Transitions 50ms
Un point important est de configurer le volume en cliquant sur le panneau de contrôle Topping USB audio device dans la barre des tâches Windows, onglet Volume puis bouton Output et enfin positionner le curseur Master tout en haut (0 dB) sinon vous aurez droit à un bruit ignoble au lieu de la musique.
Le contrôle de volume ne peut se faire que par foobar, tous les autres controle windows sont désactivé.
Merci Audiophonics pour ce super petit DAC !
DENIS G.
Excellent produit
Très bon produit, facile a installer entre mon PC sous Windows et ma chaine Hifi.
Très bon son. Je vais pouvoir enfin écouter ma collection de fichiers FLAC avec le lecteur Foobar2000 !
Paul D.
Excellent rapport qualité/prix
Un appareil bien fini, sans fioriture qui donne un son agréable et détaillé à la sortie de mon petit PC sous Linux.
Que demander de plus ?
Jean-Marc F.
TOPPING D10 - Une sérieuse alternative à tous ceux et toutes celles qui veulent profiter de la haute qualité de son sans se ruiner!
Acheté il y a quelques mois mais n'ayant pu en profiter que depuis peu, j'ai donc fait l'écoute de quelques uns de mes fichiers audio "PCM" convertis en "DSD". Le résultat, disons-le, est à la hauteur des attentes d'un tel "périphérique". Pour un tarif plus qu'accessible, il permet de redécouvrir sa collection de musique, même en restant dans sa configuration de base (fichiers L-PCM en 16bits /44.1kHz).
trudersheim c.
produit correct mais système de lecture DSD pas au point
beau produit malheureusement couplé à un PC en utilisant foobar en mode DSD il y a du bruit de fond numérique probablement
et à la longue on se focalise sur ce bruit et on entend plus que ce dernier sur mon lecteur sacd AUCUN BRUIT c'est top
Andrew M.
Great product, great service
I bought this DAC for its USB to Digital capability as my main DAC didn't have USB input. It's doing this job wonderfully. I haven't tested it yet as a DAC. It's well built and the digital display was really useful to ensure that I had the correct settings on my Mac to output Hi-Res audio.
The DAC arrived very quickly and efficiently from Audiophonics to Switzerland & they must have provided the correct customs declaration as import charges were as expected. I will certainly buy from them again.
Stefan C.
Bang for your buck
The dac is quite a big mind blow :). It sounds great connected to a pair of Pionner S DJ 80X Studio Monitors. It's clear and the sound is "edgy" and cold (it's what i was looking for).
Recommend it to users who want to upgrade twords a better sound on a budget :).
As for the guys from AudioPhonics, nice packaging for the unit and also fast responses on email. Would be nice to have an option of FedEX or DHL Express for sending packages internationally (in my case, Romania). Got the unit with colissimo in 7 days.
Wim B.
Topping D10 USB DAC works with OS/2 (ArcaOS, eComStation)
I bought this adapter specifically to develop and test USB Audio Class 2.0 support with OS/2 (ArcaOS, eComStation). It works very well with the latest (10.225) Lars Erdmann USB driver set.
Alain P.
Acheter pour dépanner ... rester en place !
Mon préampli-DAC est tombé en panne. Vite un ti'dac pas cher pour aller du PC aux amplis.
PAF dans mon orgueil d'audiopathe. Ce truc, il lui manque un potard de volume. C'est tout. Tout le reste est carrément parfait.
ETONNAMMENT parfait. Vais-je réparer mon préamp-dac à 70 fois plus cher ? Je me pose vraiment la question.
Andreas L.
Excellent Service,Great product
The service from Audiophonics was exceptional,product was received in 4 days with in Europe!
The D10 is an amazing quality DAC, i bought it for a usb to spdif converter ,i found out that the sound quality is amazing with lots of detail,it matches the sound of My Lynx 22 studio card.It runs along with more expensiveDACs. Recommended!
Jackies C.
musical mais pas totalement fonctionnel
J'en ai pris deux pensant pouvoir faire évoluer mon système tri phonique, diviser les canaux avec un filtrage numérique et utiliser les deux DAC pour envoyer sur deux ampli analogiques. Windows 10 ne gère qu'une seule carte son à la fois, Vous pouvez essayer tous les logiciels comme foobar et autres, c'est peine perdue.
je viens de rebrancher mon petit audiophonics U Sabre V2. Il fait au moins aussi bien sur mes Cabasse Sampan. De plus il dispose d'une sortie jack que j'utilise pour la section caisson basse (DIY clipschorn). Je vais prendre le minidsp 4xHD pour gérer le filtrage actif et l'egalisation.
A suivre...
Philippe L.
Compatible avec DAPHILE
Voulant transformer un vieux PC en serveur audio avec le logiciel libre DAPHILE, je reherchais un DAC USB alliant bonnes performances audio, maximum de formats lus et prix doux. Après avoir trouvé sur un site un test détaillé du TOPPING D10, j'ai décidé de le choisir. Il a été reconnu directement par DAPHILE et les résultats sont excellents.
Frans L.
Great little DAC
Very transparant does not add any color to the sound. Stereo image very precise delivery with inn 5 day's. Burn it in 48 hours (playing DSD files) without any problems no heath build up. Till now very reliable. Including 2 years garanty was one of the reasons to buy it from audiophonics instead of Alliexpress.
Daniel D.
config foobar et jriver
la config pour foobar et pour jriver se trouve ici (lien issu du site Topping).
https://www.dropbox.com/s/laf9heiphv8glfj/D10%20Manual%20and%20Driver.zip?dl=0
GIUSEPPE F.
Excellent
For the money it's hard to find better!
Daniel D.
bon produit
notice pdf d'installation détaillée pour le pilote et la config de foobar.
décode bien tous les les formats annoncés.
le son est clair et détaillé en PCM tout comme en DSD stéréo (je n'utilise pas le multicanal pour la musique).
Je possédais un U-Sabre qui faisait déjà du bon travail mais là c'est clairement un cran au dessus pour un prix très abordable.
The DAC USB TOPPING D10 includes all the on-board components to make high quality HD music. Featuring a USB Xmos U208 USB input, a DAC ESS SABRE...
