Pascal J.
Excellentissime avec aop 2210
Je l'ai essayé en lieu et place d'un Audiophonics ap310 sur mon nouvel ampli Audiophonics lpa 600nx et une grosse...
Dan I.
Acheté pour alimenter un caisson de graves clos passif (entrée RCA haut gain, bypass activé). Cet ampli réussit à piloter avec...
Gábor Ákos B.
Tökéletes!
Kiváló minőségű erősítő.
Olyan hangot tud, amit 10x áron adnak mások!
Psvane el34 C. A gyári végfokcsőve, és ez nem egy olcsó...
TOPPING D30 PRO Balanced DAC 4x CS43198 32bit 384kHz DSD256 Black - reviews - There are 3 reviews.
Pär L.
Substandard product
This DAC does not work with some CD players/transports. According to Topping, this depends on the DAC's hardware. Note that the same CD player works with other DACs, but not with this one. This is a known issue that has been discussed a lot on AudioScienceReview. In my opinion, the D30Pro is therefore a substandard product that should be withdrawn from the market, or at least potential buyers should be informed of this problem before purchase.
Modern dacs weren't really designed with this type of low res source in mind.
Many sources using SPDIF toslink are also problematic (mostly "mass market" devices).
Jens K.
A very strong contender
I've tried and tested a LOT of cheap/mid-ranged DACs in my time and this has to be one of my all time favorites. It's a nerdy 4 DAC chip design and it presents the most convincing soundstage I've ever heard in any DAC to date. No, it's not perfect in every aspect (nothing is), but at this price point it's damn close to unbeatable. For example, it easily outshines the otherwise appraised Gustard X16 DAC, even though the latter has the upper hand vs the D30 pro when it comes to detail retrieval. A five star rating is given relative to its price - well done, Topping!
Eric B.
son HIFI
je l'ai connecté en XLR à mon topping A90, son précis ,net , qui s'exprime sans retenu avec une puissance bien présente.
les voix sont chaudes ..bon achat
Powerful and compact balanced DAC, the digital-to-analog conversion stage of the Topping D30 Pro is based on no less than four Cirrus Logic CS43198...
