Lennart H.
Eric H.
Bonne qualité
Bon rapport qualité prix : fait le job !
Eric H.
Excellent câble
Très bon câble sur tout le spectre
Amène de la clarté et pleins de détails deviennent plus apparents.
Je recommande son achat
TOPPING E30 USB DAC AK4493 32bit/768kHz DSD512 XMOS Black - reviews - There are 26 reviews.
Pascal R.
Magnifique petit DAC
Que dire de ce DAC…
Il est totalement invisible au niveau audio, mais c’est ce que je ressent avec n’importe quel DAC. Il est très transparent.
Par contre il est extrêmement pratique, pas encombrant, un bel écran qui permet de bien lire le volume si on l’utilise également en fonction pré ampli, une finition très propre.
Merci à Audiophonics pour tous ces services.
Pascal
Ioannis S.
Coaxial not operate properly
Is a good DAC but the coax input operate with with continuous breaks when i connect a CD player !
Michael K.
could be problematic
Hello,
after purchaising the topping E30 in the audiophonics shop the item was delivered to Italy with some delay, maybe general christmas time delivery and not depending from audiophonics. Attention, it comes without power supply an this is not indicated very well. (you have to control the shipping list) My E30 did not work correctly, The music pieces are played with hundreds of mirco interruptions. So I can't describe very well the sound compared to my existing Project digital S2 box Dac. Very similar, a little bit darker and more cohesive. Without the malfunction I preferred it over the project S2. Due to the malfunction and scare support from topping and audiophonics I sent it back. Audiophonics said, the cannot detect errors on my E30. Tested in my hifi-sourrounding with 3 different CD-players as transport occurs always same error, same system and the project works fine. Now I'm waiting for over Two weeks to get my money back. Audiophonics say, I have to wait. Did you know that they have no telefon number.. .Their website is beautiful but if you have a problem with a product it seems its better to buy elsewhere, Michael
Elisee B.
Ne convient pas pour un système haute-fidélité
Si vous recherchez un DAC simplissime pour une utilisation haute-fidélité, celui-ci ne conviendra pas; préférez le Topping E50.
Dhafer D.
DAC Imbattable à ce prix
Bonjour
Acheté suite au conseil d'audiophonics pour piloter un AKG 702.
Excellent DAC : son détaillé, équilibré et non agressif.
Par contre j'ai trouvé que les basses ne sont pas assez maitrisées et que les medium sont un tout petit peu mis en avant (je cherche la petite bête)
Cela n'enlève en rien son coté chaleureux et son incroyable musicalité et abscence de distortion.
A ce prix franchement, imbattable !!!
MASFETY F.
Top
Dac branché en USB sur une Shield pro 2019 amplificateur Yamaha enceintes davis stratus, c'est un régal auditif
Gilles X.
5 etoiles mais j'ai bien failli le renvoyer ! attention à l'alimentation
Après de nombreuses lectures sur le net (audioscience review et consor), j’ai décidé d’acheter le Topping E30 – en remplacement d’un ARCAM Rdac defaillant.
Mes premiers essais ont été faits en « optique » avec une alimentation de chargeur de smartphone (2A). Le son m’est apparu montant, creux dans le bas medium, les basses sèches mais comme « décharnées ». En clair … pas bon du tout. J’ai tenté d’alimenter avec le PC fixe, PC portable – sans résultats probants.
J’ai joué avec les filtres et le Mode PRE ou le mode DAC, rien n’y faisait.
J’ai donc changé pour l’entrée USB (en tenant des échantillonnages sortis du PC allant de 44.1Khz – 16bits jusqu’au 32bits 392Khz …) toujours pareil. – le son était creux.
J’ai changé d’alimentation (alimentation linéaire 5V – 3A) – pas franchement haut de gamme. Idem.
J’ai mis une grosse batterie (10000mAh) pour recharger les smartphones … et là, j’ai enfin eu un SON équilibré (ouf) !
J’ai ressorti du placard une alimentation linéaire régulée (TL431+ MOSFET ) (transfo de 100+VA !)
Et là, j’ai retrouvé les résultats obtenus avec la batterie.
A FINAL : sur le net il est écrit partout que le DAC se satisfait de n’importe quelle alim, mais chez moi, avec mon système (preampli et ampli Primare + Open baffles 3 voies (2x30cmpar enceinte) ) et mes oreilles (et celles de toute la famille) , l’alim joue un rôle fondamental (bien plus que les filtres).
Une fois le problème d’alimentation réglé, le DAC est EXCEPTIONNEL pour son prix. La scène sonore est énorme (il y a de l’air entre les instruments), on localise parfaitement les instruments, les détails sont là, ils fourmillent. Les instruments sonnent parfaitement (timbres) , même les saxos/trompettes qui peuvent parfois être agressifs. Les voix sont retranscrites impeccablement. Les enregistrements de moindre qualité ne souffrent pas trop, on notera simplement une scène sonore plus petite, plus basse… Bref on pourra toujours les écouter !
Marian S.
Dac de très bon qualité.
Je l'ai acheté pour pouvoir partir plus tard sur des éléments séparés, ampli casque et dac. Je possède momentanément un Fiio K5 pro qui fais les deux. Lui aussi est de très bon qualité .
J'ai le associé au smsl q5 pro (acheté aussi de chez vous) Je constat que le son et encore mieux.
J'ai gagné donc un dac qui va me servir pour casque et pour l'ampli salon.
Merci Audiophonics pour votre réactivité et votre professionnalisme. Vous êtes au top.
Valentin S.
Un régal pour les oreilles et le portefeuille
E-30 : superb clarity and finesse, even has decent op-amp for an entry level system (OPA1612).
audiophonics: fast shipping, newest factory charge (2102XXX), ordered in march.
tres bien overall.
Michele H.
I'm in heaven!
Until today I have been relying on the DAC of my AV amplifier, but I needed highres also for my new audiophile headphones, and AV amplifiers can't properly drive high impedence headphones. This little box connected to a good amp can truly sing! I've been using it with a few flac lossless CD rips and Tidal Hifi (24/96), all streaming from a dedicated Intel NUC connected through usb (Asio drivers) . I was surprised and delighted to get 24/192 when streaming Tidal Hifi from my Samsung S21 connected via USB: tidal on android can perform the MQA unfolding via software (presumably as the Topping e30 doesn't decode MQA).
I haven't tested the spdif or optic inputs and I am using it in pure DAC mode, mostly because I always want to visualise the sampling rate. The remote is useless for me after the initial setup.
As power supplier I'm using an old ipad charger which I am sure is cleaner than the power delivery from the NUC usb, but the power utilisation is so small that I could use a battery :)
I can't yet feel any difference among the DAC profiles.
A small click can be noticed whenever the DAC switches resolution, but I'm not overly bothered as I don't switch very often using my sources.
I can't imagine a better DAC at this price. If sound quality from usb is the priority I strongly recommend this
Michael L.
Very good
It works with a windows 10 pc without needing to install a usb driver, its's 24 or 32 bit, sounds a little dry and lively, easy to control either in dac mode or pre (preamp) mode for using it with active speakers and a tv or power amp and a pc (usb power).
Egon B.
Discret
Je l'utilise comme DAC entre un chromecast audio connecté via toslink et un amplificateur intégré. Tous les deux sont alimentés d'électricité par la même powerbank bon-marché. Son plus détaillé et grave plus clair par rapport aux DACs du chromecast et de l'amplificateur intégré. Parfait pour écouter de la musique. Un peu trop détaillé à mon avis connecté à une télévision (que m'importe les micro sons de claquement, d'aspiration des acteurs ...).
À part le son, ce que j'apprécie beaucoup c'est que le DAC est toujours en mode standby, et s'éveille automatiquement dès qu'il reçoit un signal du Chromecast.
Rosen L.
A great DAC!
A great DAC overall. Miles better than D30, also better than KhadasTB. With good treble details and not fatiguing, mid's are a little life like and sweet, bass i s great but lacking a little detail. It has a sense of 3d and depth. Also instruments separation is great for the price. It works flawlessly and works well with DSD too. I Use FB2K and JRIVER on a PC.
Also when connected to a Android(6) media player with USB Spotify and Tidal cannot play. When using specialized audio player it reserves the USB connection and it plays well!
If i use optical output on the Android player it is playing great Spotify and Tidal great. On Tidal it is not outputting more than 48khz but i think my player is the problem!
JEAN-CLAUDE B.
JE RECOMMANDE
Superbe appareil pour le prix.
Carlos M.
Excellent DAC, mais Audiophonics n'a pas envoyé le même jour
J'ai acheté le Topping E30 pour remplacer le D10 parce que j'avais besoin d'un input optique et je suis très content. Un DAC incroyable pour le prix!
Le seule problème de mon achat était le service d'Audiophonics. J'ai acheté avant 11am et ils on envoyé seulement le jour suivant, pas dans le même jour!
Tibor F.
Topping
OK
Robert L.
Impeccable
Ce petit DAC fait bien son boulot, entre un PC (lecture sur Foobar en asio) et un FX tube 03, il laisse mon ancien Vdac Musical Fidelity loin derriere. Le son me parait plus doux, mieux défini, avec une meilleure profondeur, plus d'espace. La musicalité globale est agréable. L'ampli est un classe D a puce Tripath DIY sur des enceintes vintage KEF Chorale, tout cela donne un son dynamique et bien détaillé. Les chinois sont en train de faire comme le japon dans les années 60-70, ils arrivent a produire des choses de qualité, a des prix très abordables....
Igor K.
Tout simplement excellent
Rien à dire, son superbe, utilisation fiable, dsd natif, compact, prix franchement incroyable vu la qualité.
Utilisation type de l'avis: via USB et avec le pilote ASIO téléchargé sur le site de topping, en mode DAC, SR: toutes, de 44khz à DSD256.
Seul manque pour moi et mon utilisation: une sortie XLR
Clément E.
Une petite merveille
Un excellent DAC, avec une légère tendance chaleureuse mais une résolution et un niveau de détails très impressionnants ! Loin devant ma Sound BlasterX G6.
Point postif, le DAC peut être alimenté avec un cordon USB DC fourni, ou avec une alimentation secteur non fournie. Le fait d'avoir le choix est très appréciable car cela permet d'utiliser le DAC en semi-nomade sans avoir de prise secteur à disposition.
Le contrôle de volume est appréciable également, mais malheureusement uniquement via la télécommande dont les piles ne sont pas fournies.
Les trois entrées numérique permettent aussi de pouvoir basculer facilement entre plusieurs appareils (USB, Toslink, Coaxial) le tout sans avoir besoin de driver.
Je recommande chaudement ce petit DAC !
davide b.
Wonderful!
It is a dac not expensive which has a warm and detailled sound. The remote control completes the product.
Guillaume L.
Excellent produit
Après quelques recherches sur internet, je suis tombé sur ce DAC de conception récente. Notamment, le site suivant et les comparaisons proposées m'ont bien aidé :
https://www.audiosciencereview.com/forum/index.php?threads/topping-e30-dac-review.12119/
Je cherchais un remplacer un autre appareil de même type acheté il y a 4 ans. Et bien le E30 est un très bon choix. Je l'utilise comme source pour mon amplificateur Hifi. Il est raccordé en sortie (avec le branchement USB) d'un raspberry pi qui joue le rôle de lecteur réseau . Il est aussi raccordé en sortie de mon lecteur CD (branchement optique). Le E30 reçoit son courant d'une alimentation linéaire régulée de chez Audiophonics.
Le son de ce DAC est bien détaillé (bien plus que mon matériel précédent). L'image sonore est précise, la localisation des instruments ressort bien. Le son sait être enveloppant. Les basses sont propres. J'ai plaisir à l'écouter.
Roger F.
Bon produit
Top produit, au niveau son impossible de le distinguer du Sanskrit 10TH 2eme édition.
Topping: 2 modes, dac avec affichage de la fréquence ou pré-ampli avec affichage du volume.
3 niveaux de luminosité de l'affichage, qui ne peut pas être supprimé
Sanskrit : affichage de la fréquence et indication du volume si action,
l'affichage peut être supprimé
Benoit M.
Excellent son, la scène est large.
Comparaison avec un autre DAC (24 x TDA1543) : le son est dynamique et raffiné - le 'Velvet sound' du DAC AK4493. Bonne spatialisation et les extrèmes ne sont pas tronqués.
L'autre DAC me met plus près de la scéne, puissant mais moins large.
L'appareil est bien présenté et construit, rien à redire.
Je vais upgrader l'alimentation 5V, peut-être y aura-t-il encore une amélioration.
Tim R.
TR
Arrived as described, well-packaged.
- If you use Win7 or lower with a Realtek High-Definition Audio chip and Realtek driver, you need to deactivate your driver using Device Manager in Win7. Otherwise, Win7 will not see the Thesycon/Topping driver you have downloaded and installed.
- This requirement is not mentioned any where on the Thesycon, Topping, or Audiophonics websites, nor in the instructions.
- The Thesycon/Topping driver offers multiple simultaneous sources. This means it is either WASAPI or ASIO compatible. But tech support at Topping does not know which. Thesycon is uncooperative.
- The Thesycon/Topping driver does not offer visual control or choice of sampling rates. Changing sample rates on a single streaming source such as Radio Paradise does not produce a change in the sampling rate of the DAC display. So it appears to be "stuck" in 44.1 pcm mode. So it appears not to be able to provide High sampling rates as advertised.
- Higher sampling rates on Radio Paradiss with no other user programmes running (for example, streaming FLAC) produces clicking and sometimes pops.
- I therefore rate the Thesycon/Topping driver a poor. I am looking for a better driver that correctly handles the high sampling rates that this DAC is supposed to be able to use..
Patrick L.
Très bien
Bon son su mon pc portable en USB
Antonios S.
antsam
Value for money DAC. I am using optical and coaxial inputs in my system.
Clear, precise, neutral with open stage.
Useful remote control.
Excellent at this price
 (4)
The E30 from Topping is a DAC with very advantageous compact dimensions and surprising performance given its small size.
