Markus W.
Good quality
Patrick v.
Magnifiques !
Tom K.
TOPPING PA5 Balanced Class D Amplifier 2x125W 4 Ohm Silver - reviews - There are 5 reviews.
Radek P.
O.k.
I have 2 pieces connected as biamping. And it plays great. Preamplifier ADI-2 DAC FS.
ANTONIO M.
low quality built
sounds is ok if you like the shitty integrated volume, yes at leats is analog and passive but still, conectors quality are really bad. Also for being "class d2 is pretty ineficient, with 90db/w/m 8 ohm speakers it goes pretty hot the case!!! nad 216 is more efficient.
Sound quality, if using integrated volume is pretty good but i want a pure power amp with no volume or level control a nd unbalnced rca imput neutrik good quality a nd quality decent 4mm banana female shockets for speakers . Looking for next generation for Purifi class.d or topping Class-D amps. Not interested in La90 class ab, im really happy with my quad 606 and nad 216, just still looking for something like AUDIOPHONICS MPA-S125NC RCA (great built made in france quality) but with the "TPA3255 enhanced" that uses this topping pa5 and a integrated meanwell swithing mode PSU, that will be the perfect combination until Purifi makes smaller power modules
Ralph S.
Great Amp, But Unreliable
Technically this is a great amp. Unfortunately after 4 weeks mine started to emit pop sounds. Eventually after a very loud pop one channel did shut down until i turned it on off. Did send it back hoping for a refund.
Kévin R.
Restitution incroyable
J’utilise un filtre USB HS-01 pour me relier à un Topping D90se (position DAC avec le filtre 7), sorties en XLR/TRS (câbles Topping) vers le PA5 alimentant deux Klipsch R-820F (le D90se fourni la source audio à un Klipsch 115-SW via RCA (câbles Topping). C’est magistral. Précision, pureté, réalisme sonore ?
Daniel S.
TPA3255 Inside
Voici un très bon ampli, super compris à un Hypex NC122 avec des mesures ASR qui ne mentent pas.
Pour éviter le "reverse ingeniering" topping a pris soin de gommer les références sur les inducteurs, puce TPA3255, mais un démontage montre bien un TPA3255 avec des composants de bonnes factures autour. Je pense qu'il s'agit d'un classe D monté sur une typologie composite avec des OP amps masqués par la marque, mais de type probablement différentiels et un PFFB activé pour atteindre un aussi bas THD.
Je conseille de changer l'alimentation donnée à 38V / 4A = 152W. Preferez une alimentation DIY de type Connex SMPS300R ou une Meanwell, dont les ripple sont meilleurs et surtout la puissance = 300W, pour gagner en patate )
Je recommande cet ampli pour un usage Audiophile dans une pièce de taille modérée, il donne environ 2X50W / 8R en puissance réelle.
Topping offers with the PA5 a compact yet powerful and high performance balanced amplifier. It integrates a new generation of optimized Class D...
