Roland S.
Dac tv
Je viens de recevoir ce tout petit dac et immédiatement branché entre le décodeur TV et un atoll in 50 se. Je le teste en ce...
Walter V.
Excellent
Works out of the box, without configuration.
Selects sampling rate and sample size automatically.
Great product!
Cedric J.
Joli mais non..
Le pôle positif accepte 1mm2 malgres l' insertion en tube. La pâte de la masse est trop fragile . Joli, transmet le signal...
VIABLUE NF-S6 Air Silver Modulation cable Asymmetric Ø16mm - reviews - There are 2 reviews.
Marek M.
high capacitance per meter ,low resistivity.
Damon A.
Excellent value for the features.
I purchased everything needed to make two one-meter pairs of NF-S6 Air Silver XLR cables. The package was delivered to me, in the USA with no additional fees needed to be paid.
This is a fairly complex cable with very nice features compared to other DIY cables. The silver-plating, and extensive shielding are more in line with more expensive cables. The trade-off is preparing, dressing and terminating this cable was a relatively long and tedious process. For avid DIY people, this will not be a problem. However, if you're looking for something simple, the NF-S1, or buying the NF-S6 would be the best option. I would say given this cable's features and the assembly process, purchasing the ready-made NF-S6 would actually be a bargain.
For sound, the NF-S6 cables cast a broad image, and brought things forward considerably in my fairly laid-back system. On some systems, things might be too forward and/or bright. The noise floor wasn't especially silent, but the cables did bring out noticeably more detail then the Mogami W2549 (DIY) cables I recently made.
