EMMANOUIL B.
The Best Copper Wire in Earth For Hi-Fi
Don't be fooled by the the title "Wiring Cable" !! Use this wire in power and speakers cables. For power cable...
patrick a.
Relié en optique au drive et en coaxial au steamer,
ce joli petit dac offre un son chaud et musical, sans aucune agressivité.
Francois g.
Un très bon cable
Cable Utilisé pour relier un IPad avec Quobuz à mon dac : Cette solution simpliste fonctionne tres qualitativement et me...
White Round Vumeters with Controller Ø35mm (Pair) - reviews - There is 1 review.
Marlon M.
Look great, but no manual, good luck.
Nice price, I'm not sure if they work well or not because the meters didn't come with a manual and the labels are a bit misleading. The capacitors are rated at the same voltage as the AC input, shouldn't they be at least double the voltage for longevity?
The meters need the controller because they don't register like others and require higher voltages to measure sound levels (normal meters can connect directly to an output transformer for example).
Good price though, and they look good lit up, guess I will wire this up today :-p
These 35mm diameter white backlit meters are easy to mount and wire to an amplifier, giving your unit a beautiful vintage look. The meters are...
