Cyrille S.
Bon transport
Stian L.
A very good and powerful amp
Paul C.
D'une remarquable qualité
XDUOO X-10T II DAP 32bit 384kHz DSD256 - Interface USB to S/PDIF - reviews - There is 1 review.
Vitor B.
Great idea
It does what it says. Great set of cables. It is more practical to use it with Mojo than Poly. Navigation could be improved as well as manual but for the price - equivocally a 5 star product.
Paolo Marco B.
XDUOO X-10T II
Versatile digital transport with many input and output possibilities. If you're satisfied with your DAC and have enough with combersome digital sources (CD, DVD, etc.) this is the ideal solution. It comes with plenty of cables, but the OTG one is missing (in case you wanted to connect with a U card or a smarthpone.) Coaxial and toslink cable are present but with mini connectors made for portable DACs, like the Xduoo Poke or the Chord Mojo. If you have a DAC with normal RCA you'll have to purchase a coaxial cable (75 ohm) mini-jack mono to RCA.
Thanks to the Hiby link app and bluetooth it can be remotely controlled with an android smartphone. All in all a great product and an unicum in the market.
