Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
XDUOO XA-10 Headphone Amplifier Balanced DAC 2x AK4493 Bluetooth 5.0 32bit 768kHz DSD512 - reviews - There are 3 reviews.
Ricardo G.
Great product
Great sounding and fully featured product, at a very reasonable price.
Congrats also to Audiophonics for the easy ordering process and quick delivery; I will definitely consider purchasing again from them in the future.
Daniel B.
Parfait
Bel appareil bien fini, nombreuses possibilités de branchement et caractéristiques de premier ordre.
La prise en main est très facile.
A l'écoute le son procuré est simplement superbe sur toute l'étendue du spectre audio (respectueux du message originel)
De plus la possibilité de branchement symétrique est un plus.
Je suis plus que satisfait de cet achat, que je peux recommander.
andoni g.
Sounds good but...
Sounds Good but need some improvements, first buy better and longer usb cable to put the pc or phone far of dac for avoid interferences, the dac need a bit of isolation, separate the electric and audio cable if you use the rca output.
Rca output sound incredible for stereo sistems.
Filters except 4 and 2 don't work, are inaudible.
rca in dont work
The xDuoo XA-10 is a balanced headphone and DAC desktop combo amplifier. With a beautiful design, it delivers excellent audio performance for rich,...
