Cyrille S.
Bon transport
Stian L.
A very good and powerful amp
Paul C.
D'une remarquable qualité
Customers reviews - There are 18976 reviews.
ANDREA C.
AUDIOPHONICS MPA-M400NC Power Amplifier Class D Mono NCore NC400 1x400W 4 Ohm We are proud to offer you the MPA-M400NC, a mono amplifier based on the NC400 amplifier module with its dedicated SMPS600N400 power supply, which is an amplification solution...
MPA-M400NC for central duty
First impression very nice unit & clean build. Sound wise (in comparison to an anthem mrx710 and parasound a21 ) it pushes the sound out from the speaker with authority and punch. The higher the volume is up the more it seems to like it and play effortless, distortion seems inaudible but this is just after few hours and Im pretty convinced it works very well both for HT and music..in fact considering a second unit to use the 2 mono on front speakers (when budget allows it lol)
Essai longue durée du sommercable orbit 240 MKII
Après plusieurs essais dans ma configuration : Ampli Yamaha AS-1200 et Yamaha CD S 1000 +Enceint Récital Define, il s'avère que le message musical est un peu brouillon tout cela en nuances bien sûr.
En connectant mon câble Triangle Opéra tout est revenu comme j'aime. Il n'y qu'en essayant sur son propre système que l'on se rend compte si le câble testé corresponds a vos souhaits....
Giorgio P.
SHANLING UA2 Balanced DAC USB-C ES9038Q2M 768Khz DSD512 Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones / headphones) or you simply want to improve the...
Shainling UA2 dac
Dispositivo eccezionale pilota a 8/10 su uscita da 3.5 sbilanciata le mie amate e vecchie sennheiser hd 424x da 2000 ohm !!!! mentre le hidiz MS1 in ear e shure ec2 vengono pilotate con facilità a 2/10 de volume del samsung S10, il suono con file 24/192 è stupendo
...spedizione audiophonics velocissima.....ordinato lunedì mattino, arrivato in Italia giovedì mattino
packaging perfetto
Philippe J.
Montage rapide et bien documenté (attention toutefois à la partie écran, pour ma part j'ai surement oublié un film ..)
Très fonctionnel avec sa télécommande, la qualité est au rendez-vous, je découvre des sons qui était quasi inaudible avec mon ancien système.
Un petit bug de son, manque d'intensité au démarrage mais reprend de la vigueur en utilisant le gestionnaire de volume de l'application volumio. Curieux.
Esthétique de qualité.
Je conseille.
Jean-Emmanuel M.
Bien mais améliorable
De base, il fait quand même des trucs un peu bizarre dans le registre les médiums-aigus. ( sur système haut rendement )
J'ai donc commencé par mettre de meilleurs condos en entrée.
Ensuite j'ai remplacé les potentiomètres 50KOhm
( Cette valeurs nous vient historiquement des pick-up Pièzo depuis longtemps révolus ) par un pont de résistances adapté en impédance ( Les câbles coaxiaux des RCA font 50 Ohm ... ). L'amélioration est parfaitement audible et elle vaut vraiment le coup. Donc 4 étoiles à cet ampli très bien industrialisé mais qui mérite quelques "tweaks".
Christopher V.
Graal sonore pour PC
J'ai récemment fait l'acquisition d'une carte Sound Blaster AE-9 qui offre la possibilité d'échanger les op amp. Ma recherche du son parfait, d’une qualité irréprochable, m’a amené à découvrir cette marque australienne, difficile à trouver par ici, j’ai pu en obtenir rapidement grâce à Audiophonics.
Couplé à mon kit son Creative Gigaworks S750, après quelques jours d’écoutes, j’ai enfin ce sentiment d’avoir atteint le Graal sonore sur mon ordinateur. Le son est tout simplement parfait et sublime, je pensais avoir tout entendu, mais je découvre encore de petits détails dans la musique, les films et les jeux vidéos. Dès la première écoute, nous avons cette impression de puissance, de pureté et de détails. Il y a peu de mots pour le décrire, il faut l'entendre pour comprendre.
Dejan R.
NICHICON ES MUSE HiFi Audio Capacitor 35V 22μF Nichicon electrolytic capacitors of the ES Muse range are specially designed for HiFi use. They therefore offer excellent performance and are ideal for use in audiophile...
Muse caps
Nice
well sound
Dejan R.
NICHICON ES MUSE HiFi Audio Capacitor 35V 220μF Nichicon electrolytic capacitors of the ES Muse range are specially designed for HiFi use. They therefore offer excellent performance and are ideal for use in audiophile...
Muse caps
Nice
Dejan R.
Muse caps
Nice
Dejan R.
DIY Case with Screen Cutout Aluminium 172x250x60mm Silver Front Panel This brushed Aluminium DIY box will allow you to cover and protect your modules, such as for example for an amplifier. The rear panel of the case has holes to facilitate the...
PGA2311 Case
Very good case, with modified display (OLED instead backlight LCD), very, very nice PREamp.
Dejan R.
ES9023 Sabre DAC
Nice sounding device, full recomendation for well listening at low cost.
Philippe J.
Cet ampli fait le job !
Car j'ai reçu le paquer, j'ai été surpris par le poids du colis! En ouvrant le paquet et en soupesant l'appreil on se dit qu'il y a du sérieux dans la conception.
Incontestablement cet ampli fait le job, je dirais qu'il est neutre et objectif, si il n'enjolive pas la musique, d'un autre coté il n' absolument aucun défaut.
Il est à la fois sobre et chaleureux, bravo à Audiophonics pour cet apprareil!
Yves R.
super
après bien des essais avec des AOP cette sortie I/V de dac est superbe: simple (il n'y a pas a choisir une montagne d'AOP) ampleur du son, détail… bien pour mon système.
Bogdan B.
Really good PSU (build and weight), using it to supply clean power to the Node 2i on the 5V rail and nearby router on the 12V one. Can not comment purely on the PSU but both the upgrade board on the Node with the power supply deliver a superior sound. More clarity, realism and surprisingly better bass weight. Definitely worth it, a quite considerable upgrade.
Thanks Audiophonics team!
Roman Z.
LOXJIE D50 DAC AK4499 USB XMOS Bluetooth 5.0 MQA 32bit 768kHz DSD512 Loxjie presents the D50, a resolutely modern DAC based on an excellent AKM AK4499 chip and XMOS USB interface. It supports PCM streams up to 32-bit / 768kHz, DSD512 and MQA...
LOXJIE D50 DAC REVIEW
The LOXJIE D50 DAC is a fanstastic product. It is sonically extremely precise with a natural sound. The character of the DAC is not very direct, instead it is sophisticated and very listenable. The bass is precise, the vocals are natural, the highs are clear and precise. The overall structure of the sound is balanced and dynamic. The DAC doesn't inflict fatigue on its listener and it's very enjoyable. Of course the DAC isn't the only important part, the RCA interconnect cables are also very important (as well as all your other equipment). I heartily recommend this DAC to all music enjoyers and audiophilles, I'm certain that its quality is comparable to DACs of even the 1500€ range.
J'ai opté pour ce sp1100 pour sa triple isolation et sa grosse section occ et pas déçu du tout. Sur mon ampli YBA et preamp phono Pier Audio il fait des merveilles. Branchement fait avec des prises Viborg, c'est du 5/5 pour moi.
Petit lecteur cd très efficace, même non rodé les graves sont présents et bien charpentés, les médiums sonnent vrai, et l'aigu pas acide. C'est un beau début, je ferai un test avec un dac externe histoire de voir mais ca marche déjà très bien, dynamique et détaillé.
Herve C.
1 an déjà
J'ai acquis cet historique et mythique ampli, il y aura bientôt un an déjà. Surpris dès sa mise en service, et avec une alimentation et filtrage largement dimensionnés, cet ampli s'est montré depuis vraiment extraordinaire, simple, puissant et précis je ne l'ai jamais pris en défaut. Il exige de très bons haut-parleurs et des enceintes de bon rendement. La puissance annoncée parait modeste mais à l'écoute ce sont de vrais watts puissants, détaillés, une scène sonore d'une réelle précision, Patricia Barber, Diana Krall, Bach aux mains d'Alexandre Tharaud des variations Goldberg exquises, Grégory Porter est là, sa voix puissante est rendue merveilleusement. L'ampli nécessite un budget certain en périphérie, mais l'ensemble est hautement pertinent de l'avis d'amis exigeants. Il a été testé chez eux sur des Rogers et sur des Focal, les essais ont provoqué l'étonnement.
Stephane E.
Simple et excellent !
Hello,
Tout d'abord merci à Audiophonics pour la qualité de service, livraison rapide et sans souci.
Concernant ce commutateur amp-s et bien je suis très agréablement surpris.
Je souhaitais faire cohabiter mes triangles lyrr XS avec un ampli hc Yamaha dspz7 et un "vieux" Pioneer A-717.
Les essais de connexions en preout ne me satisfaisant pas, je cherchais une autre solution.
Et bien j'ai trouvé avec l'Amp-s
Tout d'abord le boîtier est de bonne qualité, bien fini (full métal) et construit serieusement. Il suffit de l'ouvrir pour s'en apercevoir : les borniers sont bien serrés sur la platine arrière, les pattes sur lesquelles sont soudés les fils sont isolés avec de la gaine thermo, le bouton de commande est verrouillé fermement, c'est propre sans fioritures.
A l'écoute, il est totalement transparent, même pendant 3 heures d'écoute a haut niveau ... Et pourtant les Lyrrs ne pardonnent pas.
Je garde le son vintage du du Pionneer (graves profonds et moelleux, médiums incisifs) sur Vinyls/cd et la dynamique explosive du Yam en HC. Aucune détérioration audible, il se fait totalement oublié !
Donc vraiment satisfait de ce boîtier.
Une seule remarque qui lui fait rater la 5e étoiles : les borniers mériteraient d'être 5 mm plus profonds pour y rentrer entièrement un fiche banane "standard"
Sinon très bon produit et prix sommes toute correct au regard de la qualité.
A+
Steph
Pierre-Louis L.
Fx Audio... A confirmer après rodage.
En lisant les avis des uns et des autres j'ai voulu ajouter ce préampli en l'installant à la sortie de mon déjà très bon ATOLL PR300 . L'ampli de puissance est un KECES S125 - Mes enceintes sont des JBL L112 . Résultat : Les premières écoutes sont un peu décevantes. Je suis maintenant à une dizaine d'heures d'écoute. Certes, il y a plus de basses mais le médium est très légèrement amputés , je perds un peu en lisibilité, voire il apparait un très ( très ) léger souffle avec le FX audio tube-03 qu'il n'y avait pas avant.
Je rajoute une alimentation linéaire ( audiophonics ) et pour l'instant rien ne change. Il faut espérer que le rodage des nouveaux câbles RCA et des Tubes du FX-Audio vont améliorer le tout sinon je repartirai sur ma précédente configuration qui me donne déjà beaucoup de satisfaction. J'ai vu aussi qu'on pouvait changer les OP amp et les tubes. J'essayerai cette option si je vois que le rodage améliore le son. Bonnes écoutes à toutes et à tous ! Pierre-Louis
complément sur mon premier avis
Au niveau de la qualité et de la fabrication du câble je n'ai rien à rajouter, mais pour l'écoute, j'ai repris mon ancien câble USB FURUTECH GT2 qui est aussi un câble en cuivre OCC et là le câble FURUTETCH est largement supérieur. Bien sur le câble NEOTECH apporte une bonne écoute mais il manque quelque chose au niveau de la dynamique. Peut être est ce du à une meilleure adaptation avec mes appareils, mais cela montre bien que le choix peut s'avérer difficile sans un essai .
Bernard N.
Parfait pour ampli anglais
Je devais remplacer les borniers de mon amplis qui n'accepte que les fiches bananes , comme beaucoup d'amplis anglais de cette génération..
Coup de bol , ces borniers sont à la parfaite dimension , au millimètre prés , de la découpe du châssis de mon ONIX :l'encastrement est parfait .
La qualité de construction est de bon niveau . C'est le genre de borniers que l'on trouve sur les petits FDA;, ils ne sont pas gigantesques , mais font parfaitement le job.
Quel joie de pouvoir utiliser du câble nu ou des fourches .
Je recommande fortement .
Yves G.
Un appareil hors du commun
L'appareil est en fonction depuis une semaine, et mes explorations sonores avec lui ne sont pas encore terminées. Choisi sur le conseil de David Aubert, arrivé sans encombre, très bien emballé. Ce préampli est anonyme, mais on peut assez facilement retrouver son origine sur certain site chinois, où il est présenté comme un clone (sonore ? car l'apparence ce n'est pas ça du tout) du monstrueux préampli allemand MBL6010D. Le design du préampli est peu commun, avec ses touches en alu (?) munies en leur centre de led bleues, et avec ses pieds dorés (faute de goût à mes yeux, mais pardonnable et aisément masquable). La machine donne une rassurante impression de solidité. Télécommande en plastique, un peu cheap. Le tout sans aucun mode d'emploi, ce qui est un peu déroutant mais n'est pas un obstacle, tellement l'utilisation coule de source. Aucun problème pour l'installation, entre un DAC SMSL SU-9 et un ampli MPA-S125NC XLR stéréo classe D NCore alimentant des Q Acoustics 3030i (chaîne de bureau). Pour mettre en route, il faut actionner l'interrupteur arrière, ce qui fait clignoter discrètement le bouton Power sur la face avant. Ne reste plus qu'à choisir sa source en appuyant sur une des cinq touches à disposition (ou en se servant de la télécommande). L'action enclenche des relais, dont on entend les clics très francs en même temps que s'allument les leds de la touche Power et de la touche source choisie. Il faut dès alors actionner le gros bouton de volume (ou la télécommande) pour atteindre le niveau sonore désiré.
Et là c'est un vrai plaisir ! La qualité sonore est au rendez-vous : délié, détail, fruité des cordes, fermeté des graves, scène sonore large et profonde, le... pied ! Et je pense que ça va encore un peu s'affiner avec le temps. Mais ça ne pardonne pas pour les mauvais enregistrements.
Attention : à l'extinction, le volume se remet à zéro tout seul (ce qu'on a tendance à oublier lors de l'utilisation suivante, car le bouton ne revient pas à sa position précédente, qui n'est pas mise en mémoire, apparemment).
Les fonctions de la télécommande sont basiques : ouverture/mise en veille, choix des sources, mute, volume + ou -.
En bref , les moins : anonymat (vite démasqué), design un poil baroque, absence totale de documentation. Les plus : qualité de la construction, facilité d'utilisation, qualité sonore exceptionnelle, et... le prix !
Joachim B.
A true gem
I must admit I was sceptical at first. A first rate preamp at this price. But now I'm a convert. This piece of kit is excellent. All the way down to the construction. It sounds amazing, beating out a lot of preamps that I have in my possession many times the price of this unit. With better soundstage, clarity and separation. The only caveat is that the gain might be a little hot for some amps. Many thanks to David at Audiophonics customer service.
DAVID H.
très Satisfait
Je suis un objectiviste donc pas très fan du "son " prétendu des amplificateurs. Mais ayant des enceintes difficiles à driver j'ai décidé de me lancer dans l'achat d'un fameux Purifi 1ET400A. Le prix est très compétitif. J'ai rencontré un problème : une boucle de masse (j'entendais le son des HDD dans les enceintes)... après plusieurs tests cela venait de mon installation car la même multiprise partageait l'ampli et mon PC. Je conseille donc d'utiliser ce modèle sans autres électroniques type PC, box, chargeur de téléphone sur la même prise. Merci à l'équipe d'audiophonics pour les réponses à mes questions.
Câble USB qui s'éfface devant la musique.
Ce câble offre une belle fabrication et sa souplesse est un plus. Cela évite les contrainte sur les connecteurs. Il apporte une grande transparence et se fait oublier. Il n'y a pas d'aigus cristallins, de grave puissant etc...Il y a la musique, toute la musique rien que la musique. Son prix est raisonnable, loin de certaines productions qui frôlent des prix délirants et qui appellent plus de questions que de réponses. Ici, nous avons un câble qui apporte une grande satisfaction auditive difficilement surpassable au regard du prix.
Cédric T.
Super son
Pour le prix je sais pas si il peut avoir mieux.
Comparé à mes Audioquest Evergreen, le son est plus détaillé, surtout sur les aigus, il y a de la profondeur et de la dynamique.
Construction exemplaire tout en restant souple
Cédric T.
Superbes !
Super fiches.
Le design est idéal pour la soudure et le soudeur débutant.
Le build est bien, et très correct, le tout a résisté dans soucis à la température.
LAURENT L.
Exceptionnel
Voici un DAC exceptionnel, je l'ai comparé à des concurrents 6 au fois plus chers et il fait jeu égal. Par contre il demande bien 200 à 300 heures de rodage pour que les composants Mundorf de l'étagère sortie analogique se rôdent, une fois ce cap passé on ne peut rien reprocher ace convertisseur tout y est: timbres, dynamique, résolution.
LAURENT L.
Déception
Grosse déception, pourtant utilisé avec un Dac de la même marque Singxer, attenuation du signal sonore de 15 db ce qui est énorme.
Miomir K.
Excellent DAC
I use it via a USB connection to a Sony TA-F3000ES amplifier that powers the Wharfedale Diamond 230 speakers. I am very happy with the purchase.
A : Stephane B
J'ai fait la même expérience que vous, au départ l'ampli semble merveilleux partout, mais manque de relief, de tessiture, et devient vite ennuyeux. Fonctionne mieux dès qu'il est mis en route, soit froid, ou fatigue auditive, je ne saurais pas répondre.
Ces amplis semblent exceller dans le grave, c'est l'utilisation que j'en fais à présent.
Associez le à un Mosfet classe A pour la section médiums/aigus, ou carrément atteignez le nirvana en l'associant à des amplis type SE en 45, 2A3, 300B, 811, 845. en fonction du rendement de vos haut-parleurs, et de vos goûts musicaux.
Milan H.
Plug&play experience
Unbox it, plug to you PC, done. No drivers, no headache. Sturdy build, USB-C. Perfect
recablage d enceintes
j était un peut inquiet pour le diamètre de seulement 2 mm2. et bien sais super.. aigus sans tonique ni stridente.. doux et soyeux. medium riche de détails .instrument a leurs place. Les voix sont très naturel et chaleureuse dans le bon sens. les graves sont bien tenu. Serré et dynamique. l image stéréo et bien agencée et profonde. Un petit câble qui paye pas de mine qui monter sur mes xo jmr de 1987 redonne toute sa présence sa dynamique. Excellent aussi en câble hp pour la petite chaine de mon amie. Cayn st200 et une paire de Kef et lecteur réseaux sotm m100. jsa ma donné l envie de me mettre a la haute définition.. ;-)Ps: pour des woofer de plus de 150mm préférer les oayde across en 2.8mm2. idem pour une enceinte dépassant les 80w /120w crête. les across sont superbe. pas besoin de dépenser plus si vous rechercher avant tous naturel détails et présence et dynamique contrôlée. du vrais bon matos d audiophile.
Quentin B.
Au Top
Couplé a un cable isolé ce dynavox fait formidablement bien son job!
Claude W.
Une merveille
Utilisée avec un Sennheiser HD 800 S la symétrie apporte un gain de clarté et une descente dans le grave incroyable. L'apport audiophile obtenu grâce à cet adaptateur est sans commune mesure avec la modeste dépense effectuée pour tirer plein parti d'un ampli Topping A50 avec une sortie symétrique de 2,5mm. Bravo.
Pedro V.
Good cable, some quality-control issues
The cable appear very nicely finished, but the metal ring that differenciate L/R are less practical than simple color coded plugs.
At first the cable sounded a bit muffled and "wrong", but after a while I tried reversing it and the sound opened up. Conclusion: I think the directional arrow were assembled the wrong way round - maybe some quality assurance issues?
When wired correctly I quite like it and prefer it slightly more expensive cables by QED that it replaced.
Bernard g.
Excellent produit pour un nas
Après m'être offert un bon pré-ampli (Atoll Pr300), j'ai constaté une amélioration très qualitative en particulier pour les enregistrements Jazz des années 50_60:qualité des timbres, présence de la contre basse, profondeur de la scène sonore. En revanche, J'avais un écart important de rendu sonore entre la musique écoutée via Qobuz et le même morceau enregistré sur mon NAS.
Fort de ce constat, j'ai branché cette alimentation sur mon Nas et mon routeur.
Le gain en qualité sonore est indéniable. La qualité sonore via mon Nas est montée d'un cran.
Merci à Audiophonics pour cet excellent produit qui plus est pas trop cher par rapport à la concurrence.
affaire en or
utilisant le 1220 argent dont je suis toujours émerveillé par ses qualités de timbre de précisions et de détails.. une écoute naturel presque physiologique fait de matiere et de musicalité hors paire au rapport qualité prix somme toute excellente .je voulais le comparer a sont homologue cuivre.. je ne suis pas déçu. même qualité même dynamique.. musicalité un peut plus chaude cependant.. qui plaira aussi bien au aficionados du tube que des Gas comme moi recherchant un parfait équilibre entre musicalité espace sonore et timbre au dessus de la moyenne.. monte en xlr vibors rhodium.. il excelle partout..et a quelques détails il est très proche du 1220 argent. peut être un peut plus analytique.. le cuivre et plus chaud et plus doux.. recommander sans hésitation.. un des meilleures gap du moment.. et de loin.. privilégier des rca ou xlr de la même veine.. genre eti cuivre ou furutech rhodium.. les klei cuivre plaqués argent serrais génial mais le diamètre et un mm trop grand. Ont peut enlever du diamètre sur la gaine. Mais sa demande un travail minutieux..
Tuğçe A.
Canare
hello everyone
I have done shopping from many companies abroad and I am doing it for the first time from this store.
But I would like to say that I am not satisfied at all.
I ordered 3 sets
13.80cm cable came instead of 14m
I sent an e-mail
I am not satisfied with the answer I got.
good cable i recommend
Excellent préampli solid state.
Ce JC2-FET semble remplacer l'ancien préampli Audiophonics solid state, noir, appelé JC2 par beaucoup et doté seulement de 3 entrées et qui a d'ailleurs récemment disparu du catalogue Audiophonics.
Et bien que dire du nouveau JC2-FET, de ce nouvel arrivé?
Il chauffe un peu, plus que l'ancien préampli noir, ce qui n'est pas un mauvais signe.
Tout d'abord, que les qualités du nouveau venu semblent bien supérieures à l'ancien, lequel en donnait déjà beaucoup pour 170€. Ici la différence de prix s'entend clairement. Plus de précision, de matière, de relief, les timbres sont d'une plus grande richesse, la transparence fait un bond étonnant. Mais cela ne serait rien si la musicalité, l'expressivité n'avait pas suivi cette progression. Et bien, elle est clairement plus évidente, les voix d'un opéra de Rameau, par exemple, nous interpellent, elles ne sont pas que de simples exercices stériles de style, leur humanité nous bouleverse tout simplement.
Ce préampli m'a conquis mais cela a pris du temps.
Tout d'abord, il réclame un rodage de plusieurs semaines, donc trés long, je préviens les pressés.
Ensuite, il est très sensible aux câbles de modulation, en amont j'ai mis un Van den Hul First qui lui va trés bien, en mettant en valeur la délicatesse du rendu sonore qui nous est offert, pour un prix assez démocratique.
Et puis il est trés sensible à l'ampli de puissance placé en aval: un Quad 606 est servi aux petits oignons avec ce JC2-FET alors qu'un Goldmund n'y fait pas des étincelles, mais cela ne m'étonne pas, Goldmund a toujours été un peu atypique.
Bref ce préampli offre une transparence assez incroyable mais il sert aussi vraiment la musique et ne fait absolument aucune chirurgie sonore.
Je cherchais un préampli solid state pouvant atteindre les qualités musicales d'un bon ampli à tubes et je crois bien avoir atteint mon but.
Tres bien
J'avais déjà pris deux sets et j'en ai recommandé un car c'est un très bon produit. Placé sous des enceintes colonnes, ces pointes sont parfaites.
Merci l'équipe pour l'envoi rapide et l'emballage nickel.
Romain R.
Très bonne finition
Un câble très bien fini, la qualité est au rendez-vous.
Romain R.
Excellent appareil à prix raisonnable
Ce petit appareil a un excellent rapport qualité/prix. Le design est sobre et efficace. La finition est très bonne même s'il faut être évidemment précautionneux, notamment avec le connecteur USB-B. La restitution sonore est de qualité.
Configurations testées :
- connecté à mon lecteur CD et enceintes sans ampli, belle restitution sonore quel que soit le filtre utilisé.
- connecté à mon PC en USB, bonne restitution avec de grosses différences selon la qualité de la source (fichiers audio, vidéo, jeux, internet et streaming ...) et le filtre utilisé (avec purifieur audio en entrée de DAC).
- connecté à mon PC via Bluetooth, excellente restitution sonore à 3m, scène large et aérée, bluffant ... et plutôt cool pour supprimer les câblages !
Conclusion : je recommande vivement ce matériel au regard de son rendu et de son prix.
PS : merci à Audiphonics pour l'envoi très rapide, l'emballage de qualité et la traçabilité du produit.
Benjamin V.
Dac Magic
Après un Audio-GD depuis 4 ans, j'ai voulu essayer et je suis ravis. Le son est tout simplement Magic avec un Supernaite 3 et des 702S2 ... on entend réellement les instruments, les doigts sur les cordes de guitare, les marteaux qui tapent sur les cordes d'un piano, les cymbales vibrés. En Live vous pouvez différencié la salle et le placement du chanteur.
Je l'adore sur des lives unplugged et sur des B.O. comme John William à Vienne!
Dans le cadre de Films, je me sens bien plus au milieu de l'action qu'avant.
L'affichage des fréquences d'entrée est très utile. J'ai pu me rendre compte que certaines sources dégradé les signaux ...
J'avais très grandement sous estimé le Bluetooth : parfait pour la télé, Shield Nvidia et box android, écoute de Spotify dans des soirées avec du monde!
Rafael S.
fansastic
I've replaced my old hi-end mono amps pair, 250W/4 ohm for listening to my classiques Dynaudio Confidence 5 (4 ohm, 80 dB/W/m). I am surprised this Ncore sounds absolutely transparent, no sound signature. I've noticed lower distorsion when playing loud, I cannot hear amp limitations. My room is about 27 m2 so this 250W works well. For a larger room and a so low 80 dB/W/m sesitivity a 400~500W could be necessary if real world SPL is wanted. The trigger input is very suitable. The amp remains cool even when playing loud. The box is ok and no luxurious kind of. This Ncore is almost perfect, immo.
Cédric A.
Gold Plated USB-C to Micro USB Cable OTG 20cm As USB-C ports become more and more common, especially on smartphones and computers, this type of USB-C to Micro USB cable becomes an essential element. It will allow you to...
Perfect !
RAS, c'est un câble qui câble bien.
Cédric A.
FX-AUDIO D502BT Amplifier FDA TAS5342A Subwoofer Output Bluetooth 5.0 2x60W 4 Ohm Black The FX-Audio D502BT is, as its name suggests, the successor to the D502. The D502BT takes over its base and components, but this time it comes with a Bluetooth 5.0 receiver,...
So far So good
Un rapport qualité prix imbattable pour une installation avec de vieilles 3 voies Kenwood. Branché en usb sur un PC en 96k. RAS après qq heures d'écoute, pas aussi bon que mon vieil ampli Kenwood avec sa paire de Célestion mais encore une fois pour le prix c'est top.
Vincenzo v.
Power cable
Great neutral sounding power cable.The main quality of this cable is the excellent mid / bass details, full bodied / full sound not fat, great well articulated bass, never fatiguing high range, good 3d.I got great results on the amp integrated. Quite stiff cable. It pairs well with neotech 75 ohm coaxial cable, purchased / reviewed on Audiophonics. Tested on a high level system. Of course always excellent products from Audiophonics. Widely recommended cable also considering the price.
Vincenzo v.
Coaxial cable neotech
Excellent coaxial cable, tested on cd mechanics, network streamer, with excellent results.Neutral cable, excellent instrumental separation, excellent voice definition, excellent 3d.The cable immediately sounds good, but I recommend at least 20/30 hours of running-in. That at this price you can not find better. Tested on a high level system. Highly recommended.
