Markus W.
Good quality
These binding posts are very cost-effective. Build quality is massive contrary to most of the comparable products in this price...
Patrick v.
Magnifiques !
Tom K.
Customers reviews - There are 18954 reviews.
Dmitrijs R.
Simple, good sounding amp
The MOS-120 is a very nice amp, I like it a lot. Sounds quite warm, without substantial coloration - all as per my taste. The build quality is also great. I would recommend it to anyone, who searches for a very simple, compact, single input amplifier.
Louis M.
manque de definition et d'equilibre
de la puissance, du volume, mais quid de la definition et de la musique ?
pas de la hifi...
Louis M.
NEUTRIK NC3MX-BAG 3 Way Male XLR Connector Silver Plated Ø8mm (Unit) This 3-pin XLR male Neutrik NC3MX-BAG connector allows quick and easy assembly, consisting of only 4 pieces and no screws. It benefits from a compact design, a sturdy Zinc shell...
bonne prise
parfait contact, pas de defaut
Louis M.
neutre mmais...
l'appareil est solide et presente bien, il n'apporte pas de coloration
mais...le bouton est lisse et il ne se manoeuvre pas facilement tant il manque de grip...
Louis M.
tres bonne prise jack, fontionnement totalement neutre
Louis M.
cable qui possede la caracteristique la plus interressante : il se fait oublier...
neutre et bien construit
Gautier C.
SOMMERCABLE EPILOGUE Modulation Cable Male XLR to Female XLR 2m (Pair) This high quality XLR cable pair consists of a Sommercable Epilogue modulation cable and Neutrik connectors, specially designed for optimal signal transmission. The cable...
Top, livraison rapide, bon produit
Un standard le Sommer XLR en quad. Très bon câble
Angelo B.
CANARE STAR QUAD L-4E6S RCA cable (Pair) 1m
Excellent quality RCA cables and made with great precision. Thanks to David and Madeleine.
EXCELLENT RAPPORT MUSICALITE / PRIX
Mon avis sur ce petit MOS 120 se réfère à une expérience personnelle de quarante ans où j’ai possédé pas moins d’une dizaine d’amplificateurs de classes A, AB et plus récemment de classe D. Le MOS 120 a une sonorité typique des bons amplis de classe AB à base de Mosfet, les timbres sont pleins, avec un grain enviable, la définition est bonne sur tout le spectre, l’image stéréo est exceptionnelle pour un produit proposé à ce prix, panoramique, vaste dans les trois dimensions de l’espace. Toutefois par rapport aux amplis de classe D, ce MOS 120 ne possède pas la même franchise, sa dynamique est plus sage et cela est assez regrettable pour l’expressivité. Le MOS 120 ne possède pas non plus une transparence aussi poussée que la plupart des classes D, en particulier si on la compare à l’étonnant Aiyima A07 max, il subsiste en effet un très léger voile, ‘scorie’ typique des classes AB quels qu’en soient leurs prix. La restitution est assez satinée voire mate ce qui ne plaira pas à tout le monde mais confère une douceur souvent appréciée. Bref, un très bon ampli de classe AB avec des limitations typiques de cette classe. Pour ma part je trouve que les bons amplis de classe D surpassent les classes AB en matière de transparence et de dynamique et font jeu égal en image stéréo.
Jerome g.
belle surprise
je cherchais un ampli pour alimenter une paire de vénérables ditton 66 , sachant que la classe D a cette singularité d'y parvenir sans se ruiner .
l'essai est transformé ; les 30 cm des graves sont tenus , le MD 500 des ditton permet aux médiums de s'exprimer avec amplitude mais sans excès et pas de brillance dans les aigus ;
ça fonctionne déjà fort bien avec les aop 5532 d'origine
testé avec les oracles 2.2 l'équilibre des registres en maintenu avec une touche de douceur
les muses 02 respectent toujours l'équilibre graves méduims aigus et amènent un élargissement de la scène
superbe stéréo , excellente dynamique
je reste avec les muses 02
je n'ai pas fait l'essai avec mes klipsch rf82 , j'ai peur que ça brille un peu dans le haut , mais avec les ditton et toutes autres enceintes de ce type le fosi doit fonctionner à merveille
mes sources : airdac nuforce + fichiers flac du pc / platine cd technics sl pg 420
bref un excellent rapport qualité prix pour ceux qui peuvent se contenter d'une seule entrée analogique
j'envisage l'ajout d'un dac XDUOO XQ 50 pro 2 ou une aiyima T8 pour étendre la connectique
Romuald K.
Digital Interface USB Amanero / Bluetooth 5.0 to AES / SPDIF / I2S 32bit 192kHz DoP128 This small, high-performance digital interface takes a Bluetooth 5.0 or USB signal as input and then outputs it in I2S (via HDMI), AES, Toslink Optics or Coaxial. The Bluetooth...
Working well
Using it for 1 week only, tried I2S and TOSLINK output on headphone DAC/Amp with Foobar and Tidal on Win11. Driver installation without problems, output to the interface showing on the list. Sound is very good, clean and spacious. On few occassions short noise when PC loads a big piece of software, most likely nothing to do with the interface itself. Overall - too short experience to be decisive, but so far so good. With driver installed the interface works out of the box, provides multiple output options, everything as described on Audiophonics site.
Laurent D.
Bien mais vis fragiles
Boîtier abordable, facile à usiner, dans lequel il est très pratique d’installer des circuits et des connecteurs.
Inconvénient : les vis latérales, plantées dans la tôle d’aluminium des façades, tiennent très mal. Si on les serre un peu fort, ou qu’on les prend un peu de travers, on flingue tout de suite le pas de vis. La solution consiste à remplacer les vis d’origine par de courts boulons M2,5 ou M3 en collant l’écrou derrière à la super glue.
Dommage également que ce format de boîtier ne soit plus commercialisé en hauteur 40 mm, ce qui était bien utile pour des montages compacts.
Pierre S.
Insulated Female Blade Terminal Gold Plated Ø2.8mm (x10) These female terminals allow fast and efficient connections. Its contacts are gold plated to ensure good conductivity and resistance to oxidation. The conductor is simply...
J'ai cherché longtemps des cosses efficacement clippables sur les picots d'alimentation des transducteurs SEAS (tweeters, woofers) et celles-ci font parfaitement le job.
Harry H.
VIBORG XM203AG Male XLR Connector Pure Silver PTFE Ø11mm Black (Unit) Viborg's XM203AG is a premium XLR male connector, using pure silver contacts to provide maximum conductivity. It also features PTFE insulation and a rugged aluminum body with...
super connectors
see my review from the female connector.
Suberp!!
Harry H.
VIBORG XF203AG Female XLR Connector Pure Silver PTFE Ø11mm Red (Unit) Viborg's XM203AG is a premium XLR female connector, using pure silver contacts to provide maximum conductivity. It also features PTFE insulation and a rugged aluminum body with...
Very best XLR connector
I have tried a lot of XLR connectors but this is the very best.
Combined with the Neotech nemoi 1220 rectangular silver cable it is a marvellous combination. In our friend audio group we compared it with timber cable with Furutech connectors (1250,= euro) but the Neotech with Viborg pure silver contacts was the absolute winner
Francis B.
Il dépasse largement, ce qui est étonnant déjà, le HPA-S500ET version ampli stéréo que j'ai apprécié beaucoup pendant quelques mois. Maintenant passé sur les voix surround G et D.
Avec sa propre alimentation Hypex on a un sytème double mono incroyable.
Il est plus subtile. On entend clairement les niveaux de basses, les détails fourmillent. A faible volume les détails sont présents à fort volume pas de distortion. Un régale.
On a non seulement un sytème en HC formidable pour les dynamiques importantes dans les flms en RCA (vraiment un apport important en front, surround et back avec les audiphonics le son est clair et ne casse pas les oreilles même avec des transtoires complexes alors que j'ai le NAD T778 déjà réputé pour sa dynamique sur tous les canaux) et en stéréo XLR sur un bon lecteur réseau comme le UD-701 TEAC un son merveilleux pas du tout fatiguant. Pour un prix vraiment raisonnable et un très bon SAV et surtout de bons conseils pour optimiser l'installation.
Avec un HPA-S400ET également pour les surround back G et D on obtient des détails impressionants sur des films surround sans avoir les oreiles qui vrillent même à fort volume c'est génial. Grand merci à Audiophonics pour nous permettre d'accéder à ce niveau de son.
Yannis G.
Nice choice
After a SU6 dac that unfortunately broke irreparably at 15 months, I decided to proceed with the purchase of this dac since the various reviewers said good things.
Well it's excellent, more balanced, wide, airy and accurate, with excellent clarity for the money always, dynamic at full and very accurate. It looks and is superior in quality to the previous one, heavier with a better chip I think to the 9038.
It has been combined with a SMSL amplifier DA-9 which is powerful with good currents and 2 Polk R100 bookshelf speakers for desktop use (optical connect with pc).
I'm happy and haven't found a flaw yet.
Audiophonics 10/10 at all, order and shipping!!!
Dario G.
Dégraissé bien les basses fréquences, d'où une dynamique bien supérieure.
Un peu juste en terme de recommandation du poids pour mes enceintes mais le retour en arrière n' est pas envisageable !
Pour le prix, très bien.
NEOTECH NEVD-1001 Coaxial Cable 75 Ohm Pure Silver OCC Quad Shield Ø7.6mm The Neotech cable from the NEVD series has been carefully designed specifically for the transmission of digital audio signals. The main characteristic of digital audio signals...
Excellent câble 75 0hms
Grande amélioration par rapport à mon ancien câble Canare, qui demeure un excellent rapport qualité-prix. Le son est plus transparent, plus doux, plus vrai, avec une image large et profonde.
Francis B.
Et pour un prix raisonnable...dans la philosophie Audiphonics.
Albin A.
DENAFRIPS TERMINATOR II 12TH DAC R2R NOS Balanced 24bit 1536kHz DSD1024 Silver The Denafrips Terminator II 12Th is a high-performance, balanced R2R NOS DAC capable of delivering incredibly pure, rich sound. It benefits from an uncompromising design,...
Super DAC Ultime
Vraiment bluffant !
Rendu véritablement analogique
Signature sonore plus chaud mais dans le très bon sens du terme
S'écoute pendant des heures avec le plein de détails, timbres, ouverture sonore etc (à voir ce que cela donne associé avec le DCC mais franchement déjà comme ça c'est excellent)
Ne regrette pas un instant mon achat
Emmanuel p.
très bon connecteur
réglage de l'angle par vis intelligent, permet de très facilement passer un gros cable
philippe L.
SMSL A200 Class D Amplifier Infineon USB HDMI ARC Bluetooth 5.0 2x70W 4 ohm The SMSL A200 amplifier is a Class D amplifier incorporating two Infineon MA12070 amplifier chips for output power of up to 2x 70W @ 4 ohm. Versatile and compact, the A200...
Attention à la description qui est erronée sur la sortie Sub.
Pas de sortie Sub sur ce modèle. Je me permet de le rajouter en commentaire pour les potentiels acheteurs, mon mail à audiophonics pour corriger l'erreur étant resté à ce jour sans effet.
Cette erreur provient de la fiche fabricant. nous prenons contact avec lui et corrigeons au plus vite.
Maxime R.
FX-AUDIO L07 Class D Amplifier Infineon MA5332MS 2x 200W 4 Ohm / 1x 400W BTL 8 Ohm The FX-Audio L07 amplifier completes the series, following in the footsteps of the R07 headphone amplifier and the DS07 DAC. Featuring the same form factor, it is particularly...
Très bon achat
Alors impression des premières secondes : c'est boomy !
Les basses sont clairement mises en avant.
Mais l'équilibre général du spectre sonore reste préservé, et c'est très important (je ne suis pas trop porté sur les basses). Et puis elles sont bien définies, assez sèches, ne bavent pas. On s'en rend compte sur les morceaux riches.
Les médiums sont excellents. Nullement étouffés par les basses, ils demeurent au premier plan. Chaleureux, vivants, pas fatiguants. Les hauts particulièrement. En opéra, les sopranos s'écoutent plein volume sans fatigue.
Les hautes fréquences passent bien également. Saxophones et violons sont soyeux, bien définis, pas de brillance.
L'ensemble de l'écoute ne manque pas de détails. Sur Whole outta love de Led Zepp il ne manque rien.
Il parvient également à sublimer les morceaux mal enregistrés, et ça c'est éloquent je pense.
Mais éventuellement le seul petit reproche c'est un léger manque de délié sur la restitution quand la scène est très chargée.
Mais bon, je sors d'un Topping PA5 qui excellait dans le domaine je trouve...
Bref : un ampli très musclé (on ressent bien la réserve de watts), généreux sur les basses sans déséquilibrer le spectre sonore, avec du détail et une scène stéréo large, mais un chouilla en retrait sur le délié lors d'informations sonores saturées.
Il vaut largement son prix cependant.
J'espère que mon charabia vous aura été intelligible
Grégoire Z.
Tarif très attractif et produit de qualité.
Florent L.
Regulateurs Parfait pour reglage volume du preamplie
Parfait pour réglage du volume de mon pre amplie phono, gros soucis c'est que ça bourdonne très fort si on touche les régulateur mais si on laisse comme c'est, c'est parfait.
Mats L.
Amazing cable!
I was very curious about this cable since it got such good reviews.
Bought it to test against my current Furutech FS Alpha cable.
I'm shocked how good it sounds, absolutely amazing!!
My furutech FS Alpha sounds a little warmer BUT not nearly as high resolution as LUDIC SILENOS!
LUDIC SILENOS is much tighter in the bass and more accurate than my Furutech FS Alpha,
I also think that the midrange is clearer and much more open !
It sounds very neutral and high resolution with a large 3D soundstage, yes it has everything you could wish for!
will probably replace the internal wiring in my speakers in the future as it will surely make the sound even better.
GUSTARD N18 PRO Network Switch 5x RJ45 1x Optical Fiber Black The Gustard N18 PRO network switch features 5 RJ45 Ethernet ports as well as an SFP fiber optic connector and a BNC connector for external 10Mhz clock. The RJ45 Ethernet ports...
La suite
A mon avis EtherREGEN plus bonne alimentation+ bonne horloge supérieur mais plus cher aussi vu le Gustard
Horloge et signal
Bonjour j'ai aussi une horloge Gustard et un EtherREGEN et je préfère le signal sinusoïdale
Janez R.
Second one
I bought already the second one for same system. This amp is amazing. And it helped me identify and then improve other system imperfections. 'We are almost ''there.'' Many thanks to M. Sav. The on/off button light is slightly different as with first amp so if this is your second amp ask Audiophonics to send you an amp with matching one. Thank you Audiophonics!!!
Bruno V.
Gros câble aux multiples possiblités
J'ai acheté ce câble pour sa modularité. Je l'ai pris non monté pour pouvoir choisir le nombre de brin de cuivre OCC que je voulais et de cette manière l'adapter à mon système audio pour ne pas avoir un son où les basses ne seraient pas maitrisées. Contrat rempli !
Un son ample, des médiums présents mais non criard, des aigus détaillés et des basses qui ne bavent pas.
A titre d'exemple, la totalité des brin, chez moi, donne des basses trop présentes et non maitrisées. Avec un reclocker, 4 brin de cuivre et sans clock 3 brin de cuivre. Je sais que lorsque je changerai mon ampli, je pourrai changer la connexion du câble. C'est donc vraiment bien.
Jean-Louis G.
PSVANE 2A3-Z Power Tubes Triode (Matched Pair) PSVANE's 2A3-Z power tube offers a warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than...
Great tubes!
These are very high quality tubes. They’re in fact on the same level as the Psvane 300B Z, at a much lower price. If you don’t need a lot of watts, they’re great.
... pour un appareil qui fonctionne mal !
... car lorsque je l'ai mis en marche, le canal de sortie droit ne fonctionnait pas ! Dommage, car sinon, la qualité du produit est bien présente, sans coloration du son décelable...
Qu'à cela ne tienne, ce problème m'a permis de tester la qualité de service d'Audiophonics et, comme beaucoup d'autres, j'ai pu apprécier leur réactivité : ça n'a pas traîné du tout, dès le surlendemain du signalement de l'incident, j'ai récupéré un autre appareil... qui fonctionne très bien !
En conséquence de quoi je recommande et le sélecteur de source, et Audiophonics !
Tjalling B.
Best quality price RCA to date
Awesome plugs, soundwise, looks and pricing
From now on, I will only use these
Cannot be beaten for the price and they look gorgeous
OGUZHAN O.
Quality piece for price
I use it for mogami 3103, but it was too difficult for me to pas 4 mm section, 14 mm is perfect but 4 mm too tight. I had to use grease,soap, pull-push. use knittin needles to enlarge that section. Finally did it.
Pascal F.
Pas cool …
…De me gratter 10 cms sur les 25 metres. Un câble prévu d’1,5m sera réduit .
Pas hyper grave mais généralement les vendeurs comptent plus large pour assurer.
Laurent M.
GE JAN5725 / 6AS6W Tubes Pentode (Pair) The JAN5725 / 6AS6W / 6187 is a robust, compact pentode tube amplifier. It features 7-pin connectors and offers excellent performance.
Excellents petits tubes
Echange des 2 tubes d'un petit DOUK AUDIO ST01 PRO par ces GE JAN5725. Le gain en musicalité est assez significatif. Livraison rapide et bon emballage par Audiophonics comme toujours.
Frederic C.
Construction robuste
C'est le jour et la nuit. Rien à voir avec les connecteurs BNC à bas prix que l'on peut trouver un peu partout. Le cable RCA tient fermement une fois inseré. Dommage que les bouchons de charge 75 Ohm de la même marque ne soient pas disponibles sur le site.
Eric K.
ampli casque
excellent appareil; très belle sonorité; on peut aussi changer les OP AMP selon ses goûts; très bien !
Jean-Louis P.
J'ai commandé un transformateur sur mesure Il est 100% conforme en tensions et en dimensions, les enroulements sont bien repérés et les fils sortant du transfo sont suffisamment long.
Fabriqué en Chine bien entendu. Il y a un délai somme toute très raisonnable pour du "sur mesure".
Nos transformateurs sur mesure ne proviennent pas de Chine mais d'Europe.
Cyril L.
Compact
Ce modèle est très compact pour sa valeur et sa tension de 160V. Je reviendrais sur ces modèles pour mes prochains montages qui manqueront de place.
Cyril L.
JANTZEN AUDIO COMPACT MKT 001-8100 Axial MKT Capacitor 160V 10µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Compact
Pour les montages sérés, ce modèle est très compact pour sa valeur et sa tension de 160V. Je reviendrais sur ces modèles pour mes prochains montages.
Cyril L.
MUNDORF L071 Air Core Coil 0.71mm 2.7mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
Toujours parfait
Comme toujours simplicité et qualité de fabrication.
J'adore car il est très facile d'ajuster la valeur en enlevant quelque spires puis recoller le sparadrap qui maintient la bobine.
Cyril L.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 5.6µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Utilisation // sur les médiums en guise d'un nouveau filtrage pour une paire de 3A vintage.
Très correcte pour remplacer d'anciens condensateurs hifi
Cyril L.
Très bon rapport qualité prix, en utilisation série sur les tweeters en guise d'un nouveau filtrage pour une paire de 3A vintage.
Un gros gain sur le rendu plus doux comme j'aime.
Xavier R.
FIIO BTR3K Heaphone Amplifier Bluetooth 5.0 HD CSR8675 DAC 2xAK4377A The BTR3K is a portable bluetooth receiver with DAC circuit & balanced headphone amplifier. It works thanks to a Qualcomm CSR8675 24-bit Bluetooth 5.0 chip, which gives it all...
Very low output
I bought this in the hope to improve my listening experience when using mobile devices and to be able to use wired earphones with devices that have only bluetooth (and no more jack plug). The output is at best limited to low volume, which makes it unusable in any even slightly noisy environment like a train. Metro ? just forget about it.
Basically, I found this purchase just a loss of money.
Stephane I.
Remplacement AOP CONSTRUCTEUR
J'ai procédé à l'échange des condensateurs audio ELNA BLEU (remplacé par des PANASONIC FC 50V 4,7 uf ) sur le circuit du Aiyiama A07 MAX , j'ai changé l'AOP d'origine par celui-ci,la sonorité me convient mieux , il fonctionne encore mieux avec le LME 49860, pour ma part ,c'est musical ,aéré et pas fatiguant ,un excellent TPA 3255 accessible qui mérite du cablage et des composants de qualité , que du bonheur.
Stephane I.
AOP SUPPORT
Parfait pour changer les AOP facilement , sur certaines carte , l'accés est serré, moins on touche au pattes de ces composants, moins on les abime.
Stephane I.
cablage interne Aiyiama A07 MAX
Remplace avantageusement le cablage carte vers bornes HP de mon A07 MAX , son naturel et détails révélés , basse nette et propre.
Jose Luis A.
mmm preamp
I just received the preamplifier and at first glance it has some differences from the description.
The potentiometers are not 100K but are the B 50K by the Alpha brand (Taiwan).
At first I'm going to try it but I'm left wanting to try the one with the Alps RK27 potentiometer
