Markus W.
Good quality
These binding posts are very cost-effective. Build quality is massive contrary to most of the comparable products in this price...
Patrick v.
Magnifiques !
Tom K.
Customers reviews - There are 18954 reviews.
Trés bonnes pointes
Pointes trés efficaces, excellent résultat.
Cipriani M.
All perfect.
my congratulations to all the Audiophonics staff.
KONSTANTINOS L.
I didn't throw away my money
The amplifier has a very good performance. Excellent dac performance. Drives triangle titus, sennheiser 650 and audio technica m40x with comfort and clarity. Not the same good with audeze lcd 2c. I don't like it at high volumes, above 30, but it is very pleasant at medium and low levels, below 30 volume. Compared to smsl da9 it is better. Excellent buy for its cost. Over the years Smsl has become my first choice. Worth it.
Arend B.
High end device for low budget
This is really a great device with high-end sound for little money. Easy to assemble for anyone. Unfortunately four of the screws provided were not the right size, so I had to use my own. Therefore a star deduction. Conclusion: Absolutely recommended! Excellent!
Guillaume M.
Contre pointe
Très bonne qualité font parfaitement le boulot et ont un joli rendu
Francis T.
7HZ SALNOTES ZERO In-Ear Monitors IEM Dynamic Ø10mm Jack 3.5mm The 7Hz Salnotes Zero in-ear monitors are particularly affordable, yet still high-performance models. They feature a dynamic 10mm metal composite driver and N52 magnet to...
très bien et pas cher c'est possible
J'ai choisi cet IEM d'après la base de données des réponses en fréquences du site Squiglink. La courbe des 7HZ Salnotes Zero se superpose parfaitement à la cible du casque Grado SR325e. Un model de référence pour moi en matière de neutralité. Le résultat est conforme aux prévisions. Ni boumi dans le grave, ni agressif dans l'aigu. Parfaitement plat au milieu et confortable. Si c'est bien un son HiFi neutre que vous cherchez, ne vous laissez pas influencer par le prix incroyablement bas pour cette qualité. À voir dans le temps pour ce qui est de sa longévité.
Alain M.
Single-Ended to Balanced Converter Module XLR / RCA Stereo This stereo single-ended to balanced module recovers an unbalanced signal via its RCA inputs on screw terminals, and outputs a balanced stereo audio stream...
Consommation de ce module
Vous annoncez une consommation de 200 mA pour ce module équipés de deux NE5532 !
Ca ne serait pas plutôt 20 mA ?
Je comptais faire l'acquisition de 2 de ces modules et les alimenter à partir des tensions annexes fournies par une alimentation SMPS300RE, soit une consommation de 400 mA ce qui me semble donc beaucoup.
Alexandre S.
Incroyable
Une bonne semaine que mon petit Za3 remue ma baraque.
Quel punch, une dynamique digne de beaucoup beaucoup plus cher. Même à moyen volume les basses sont retranscrites avec netteté et puissance, le corps vibre !
Une scène stéréo très ample, large, super détaillée.
Couplé avec un dac topping e30 pro II acheté un an avant sur ce même site, il anime soit une paire de jmlab profil 77 soit une paire de jmlab opal 706, les deux upgradees en MKP.
Bluffant, dingue, sensationnel, je manque d'adjectif. On est loins devant les premiers petits FDA et mini class D d'il y a deux ans.
J'ai changé pour essayé les OP amp d'origine par deux Oracle 2-02 pour pas cher, c'est une petite amélioration, notamment de la qualité des médiums mais ce n'est pas unnm changement transcendant.
Tamás G.
Symmetrical Class A
I bought a pair from this amplifier. I use a SMSL SU-9n as preamp and dac. I use xlr connector between the amplifier and DAC, and no other volume control. The two panel working in bridge. The power supply is Mean Well LRS-150-24 set on 20,8V, the output power 2x20W (calculated). I use Fischer SK 418-100 heatsinks, the temp is 60-62 degrees. I have removed the output condensers, so the output DC 10-20mV diference. No clipping when switching on. Powerfull dynamics, perfect frequenci response, no nois on output. The streo sound is wunderfull, incredible resolution. (I have other JLH1969, with condenser (Visai 2x2200uF low ERS+ Rubicon 6x1000uF low ERS + 7 x 10uF WIMA MKP), i think the output condenzer 20-30% kill the sound, primarily the bass). I use the bridge version with Fostex Fe206NV and FT17H in reflex box, 5000KHz crossover 6dB/dec, viablue SC2 speaker cable. Whit this amplifier and Speaker you can hear, a whole new side of your musics, sometimes to break down a wall...
Alexander D.
DD TC09S Male USB-C Cable OTG Silver / OFC Copper 50cm The USB-C DD TC09S cable benefits from a perfectly mastered design, using very high quality components in order to offer excellent conductivity and therefore signal...
très bon cable
très bon cable
Pedro V.
Great preamp tubes
Bought to replace tubes 13+ year Audio Analogue preamp.
New tubes are much quieter than the old ones (which are also the same brand). Sound quality seems to be improved as well.
Fast delivery and great packaging by Audiophonics!
Olgierd Z.
SMSL katastrofa
Je suis très triste après avoir acheté cet équipement SMSL AO300, pour ce genre d'argent, vous ne pouvez pas écouter de la musique, comment pouvez-vous produire un équipement aussi mauvais pour écouter de la musique. SMSL honte à vos ingénieurs
Xavier C.
Bon Produit (2)
Avec une goutte d'huile dans les axes et quelques jours d'utilisation le défaut signalé a disparu.
Donc tout bon !
Ioannis K.
Very good quality product
Connected to pre out of my amp and delivers the signal to an headphone amplifier as also to a powered subwoofer (with 5m cable).It works without any noticeable problem.It actually seems as there is not exist in the chain! Great stuff.Absolutely recommended!
Hocine H.
Pureté
J'ai acheté ce câble sur les avis et aussi pour tester différentes configuration. J'ai monté ce câble avec des RCA Xangsane à visser et aussi à souder. Le montage est simple, la gaine se dénude facilement malgrés une légère rigidité et j'ai été surpris par les conducteurs et son cuivre épais. Le meilleur résultat a été avec les fiches à visser et à la première écoute j'ai émis un "putain" tellement c'était juste, aéré, pure (le câble n'est pas encore rodé). Tout est en place avec une belle synergie, ce câble agit comme un chef d'orchestre en ouvrant une scène sonore parfaite à mon oreille, pour ce prix c'est vraiment un cadeau. Foncez vous ne le regretterai pas.
Laurent T.
Excellent adaptateur pour celui qui souhaite utiliser un câble symétrique, terminé par une Pentacon 4,4 mm (de plus en plus généralisée sur les DAP, et ampli casque/DAC) et le relier à une entrée jack 6,35 mm très répandue.
Je souhaitais pouvoir utiliser un câble, symétrique (avec terminaison 4,4mm ,haut de gamme, réalisé par un artisan) sur un ampli lampe OTL.
Mission accomplie grâce au DD DJ65B.
Qualité de fabrication excellente, matériaux de qualité et pas de perte ou d’altération sonore lors de son utilisation.
DDhifi est devenu la référence, me concernant, en termes d’adapteurs entre mes différentes terminaisons de câbles et mes différents amplis/DAC et DAP.
Je possède plusieurs adaptateurs de ce fabricant et tous me donne entière satisfaction.
Un dernier mot, sur le sérieux et la rapidité d’envoi d’Audiophonics: toujours au top, un grand merci !
Stefan N.
Eine super Endstufe!
Ich habe die Endstufe als Ersatz für die eingebauten Front-Speaker-Endstufen meines Denon AVC-6700H gekauft und bin begeistert. Super Klang und unerwartet wertig gebaut! Das Gehäuse wird bei mir - ganz anders als der Denon - nicht einmal warm, so effizient sind die Purifi-Module. Was ich nur nicht bedacht hatte: die eigentlich clevere Halbgröße bedeutet, dass man keine Standardkomponente obendrauf stellen kann. Ich wollte die Endstufe deshalb eigentlich auf die "oberste Ebene" stellen, musste aber feststellen, dass der bisher dort stehende BD-Player zu wenig tief ist ... Ich muss als erst noch ein kleines Podest basteln, damit diese tolle Endstufe nicht mehr neben dem Hifi-"Turm", sondern darin bzw. darauf stehen kann.
Pascal M.
Bon produit qualitatif. Mes pointes étant très fines ce support a sauvé mon carrelage !
Marek P.
Perfect sound but beware of DSD direct!
Sound for its price its unbeatable. But beware of DSD direct - no way to get DSD native in LAN mode - it is converted to hires PCM. Fmv 1.43. Awaiting DAC patch from Shenzenaudio.
Bernard D.
Franchement super.
Le SU-1 offre de manière générale une signature sonore transparente, naturelle et équilibrée des graves jusqu'aux aigus. Pratiquement pas de coloration sonore.
Je n'ai jamais entendu mes KLIPSCH sonner aussi bien !
Hocine H.
Efficaces
Très bon reapport qualité/Prix, c'est presque indécent au vu de la qualité du produit. Très facile à monter et surtout très solide, la connectique est bien ancrée et le capsule se dévisse/visse aisément pour une facilité de connection. Côté son ils sont propres, aucune différence avec mes viablue et je je les ai associé avec du neotech Nei 3004 de 8mm, c'est juste parfait. Je les ai testé avec plusieurs câbles, je voulais savoir si à force de monter/démonter ils bougeraient, et bien non après une dizaine de tests différents, ils sont comme sortis de la boîte. Il faudrait avoir cette marque en XLR, ce serait cool.
Anthony F.
Great amp, Great company
Needed more headroom for my Arendal 1723 monitor s speakers. Tried Fosi ZA3 300 watts per channel using monoblocs and sound improved significantly. Decided to jump to 600 watts per channel and landed on your website. Now I’m where I need to be. I was concerned about ordering from USA but pleasantly surprised when my order arrived within 3 days! Shipping was even faster than ordering in US. Build quality is fantastic and sound keeps improving with break in. This is the last amp you will need if you’re looking for more power to drive speakers with lower sensitivity. All the nuances in the recording can now be heard at volume levels that are not ear splitting. Thanks for a great product and great buying experience..
Xavier C.
Bel aspect, sobre et élégant.
Extérieur en aluminium, partie intérieure en plastique.
Un peur cher par rapport à d'autres produits techniquement semblables.
Xavier C.
Très bonne qualité, belle finition.
Prix modéré.
Serrage par vis (clé Allen 2 mm).
Convient pour un axe cylindrique, méplat ou cannelé.
Piotr C.
Great product.
Very good quality and sounds very nice.
Conrad F.
IAN CANADA UCPI Universal Ultracapacitor Power Supply Board for Raspberry Pi Ian Canada's UcPi is a high performance and affordable 5V supercapacitor power supply module designed specifically for audio applications using a Raspberry Pi to get the best...
Good value
I did a review of Ian Canada TransportPi and this was added to it. It subtly improved my overall perception of sound quality of that board. Not sure how it actually measures for noise, which is something I am interested in. But I do think the ability to run a device purely off an ultracapacitor to decouple from a direct mains supply is worthwhile.
SMSL DO100 DAC 2x ES9038Q2M XMOS Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 The SMSL DO100 is a compact, affordable and very powerful DAC, offering a careful design characterized by the knowledge of the brand. It embeds in particular two ES9038Q2M...
Récepteur Bluetooth très complet
Pratique et bien équipé, au niveau de sortie réglable par télécommande, ce récepteur BT souffre d'un manque d'indication quant aux nombreux choix de qualité audio, pas facile de s'y retrouver...
La qualité est là, mais on aurait apprécié une sortie AES-EBU
AES-EBU, la liaison idéale !
Abandonnez vos sorties/entrées SPDIF peu performantes au profit de l'AES-EBU qui vous donnera les meilleurs résultats !
Ce câble de liaison Audiophonics vous donnera toute satisfaction pour un rapport qualité prix très correct.
Balazs L.
A real step forward
Based on a year of problem-free use: accurate sound image and high level of detail, a huge step forward in my sound system
XDUOO MU-605 Bluetooth 5.1 Receiver aptX HD LDAC DAC 2x ES9018K2M 24bit 96kHz The MU-605 from xDuoo is a Bluetooth 5.1 receiver, allowing you to offer to your classic HiFi system the capacity of a wireless reception and thus the possibility for you to...
Excellent produit !
Un résultat Audio très satisfaisant, toutes les sorties utiles dispo ! Une rareté sur le marché...
On aurait apprécié une entrée AES-EBU, mais la perfection n'est pas de ce monde :)
Conrad F.
A bargain
I bought this based on positive reviews, but expected them to be hyperbole. This replaced an IQaudIO Digi+ board and was a massive improvement. Overall clarity was similar, but my system suffered in sounding hyper clear but 2D. The Ian Canada board brought weight, body and a huge amount of depth. Things are very 3D. I was not a believer that streamers could make much difference if well engineered. Well either the commercial product market is full of sub-competent engineering, or the focus on creating a low noise, ultra low jitter source with hyper accurate clocking makes more difference than those over at ASR website claim. I have enjoyed my last 2 weeks with this board and a UcPi that I've just plumped for all the flagship boards to make a no-holds-barred streamer. I reckon just this Ian Canada board I am reviewing is one of the best bargains of about 30 years in high end hifi. Those old 70s and 80s recordings that on modern digital streaming services sounded thin or cheesey now sound full 3D and immersive. More modern stuff is just more so, or louder. Everything is now like a live performance.
John T.
Excellent Amp!
Purchased the HPA-S400ET as alternative to my Parasound HALO INT 5. I am running Magneplanar LRS+ speakers and felt the extra power may deliver an even better sound than the HALO. This is exactly what happened! Paticularly in the mid and high tonal area the clarity was outstanding. I was very happy with my HALO but am now pleased I went for the PURIFY Amp. Excellent delivery service and product quality from Audiophonics!
Vincent D.
Un ampli casque transformé
Sur un petit ampli casque Audio Technica monté d'origine avec des JJE88CC, la différence est flagrante. Probablement que ces tubes commençaient à fatiguer mais là je redécouvre mon ampli. Basses tendues et impactantes, medium naturelles et aigus qui restent doux. Une scène sonore plus large, un rendu moins «mou». Je ne regrette pas d'avoir payé plus cher que les tubes d'origine pour cet ampli qui m'accompagne depuis 7 ans déjà. Livraison Audiophonics rapide et soignée, au top!
Rapport qualité/prix imbattable !!
Ce modeste câble impressionne par son efficacité sur mon iFi One Signature, il sait restituer la musique dans toutes ces nuances. C'est à décourager d'investir dans des câbles 3 fois plus chers !! C'est pas bon pour le chiffre d'affaire de l'entreprise Audiophonics qui a l'art de dénicher des produits abordables et efficaces :) !
Andrius N.
VIBORG BP-603 Pure Copper Speaker Terminals Plug Ø4.5mm (Set x4) With its BP-603, Viborg offers exceptional terminal blocks for speakers, thanks to a design using particularly high-end materials.
andrew
Amazing quality a big difference than same production from AliExpress.
Andrius N.
andrew
Perfect quality.
Peter L.
Ver nice DIY plug and play device
Works best with Volumio, in my opinion. With Volumio and the audiophonics-volumio-plugin, it is possible for me to skip tracks, control volume and shutting down proper with the remote control. Sound is very good - better than Topping DX3pro+, imo.
I paired it with pi3B+, 1GB RAM. Works fine! I build a case out of thin wood plates. Now, got a very good all-in-one STREAMER/DAC for 260 Euro!!! Nice!
But please Audiophonics-Team, make a big HINT in Github, that the old procedure of changing the kernel of raspy in order to get the I-Sabre-driver working, is NOT necessary anymore, because it is implemented in the newer os versions. That costs me hours of work, when i prepared a OS for plexamp!!!
Gerard T.
NEOTECH NEVD-2001 Coaxial Cable 75 Ohm Pure Silver Quad shielding Ø7.6mm The NEVD-2001 is an excellent Coaxial cable with an impedance of 75Ω, offering a wide bandwidth to reduce jitter and ensure maximum resolution. The cable benefits from an...
Magnifique...!
Installé sur rca canare 75ohms.
Avec dernier blindage raccordé que d un côté.
Ce câble sonne très analogique et naturel.
On ne se pose plus de question.
Gerard T.
Le câble
Bien respecter le dernier blindage que d un côté.
Musicalement ce câble est simplement "parfait"
Naturel et analogique.
Bravo
Sina M.
Look no further! Best performance vs price
Very powerful and clean amp. This is the best amp module out there for such a price range. Hook it up to a powerful PSU and take care of the wiring, you should have a great class D amplifier that can easily compete with the Big names for a fraction of their price.
Sina M.
MORNSUN LOF550-20B48 SMPS Switching Mode Power Supply Module 550W 48V 11A PFC This LOF550-20B48 switching-mode power supply module delivers 48V and 11A for 550W of power. The module features high-quality components and is...
Great Amp - Extreme low noise and proper heat dissipation
I assembled this UPS for a power amplifier project using the recent 3e stereo module. The result is very satisfactory. It has enough juice to power up 2 ELAC Tower speakers and the noise floor is non-existence to my ear. I didn't hook up a fan to the setup firstly because I didn't notice a change in the output power (it is advertised 11 Amps using the fan) and secondly the large heatsink at the bottom does a great job dissipating the heat. Keeping the setup running for hours the housing is warm to touch (32 C) and the transistor heatsinks are not too hot (40-45 C). I am very happy with the result
Hubert S.
TINYSINE TSA6017 Bluetooth 5.0 Receiver with Microphone Input The Tinysine TSA6017 adds Bluetooth 5.0 reception to a conventional HiFi system or headphone. The TSA6017 has a line output and a microphone input on a Jack 3.5mm. When using a...
Utilisé pour donner un accès Bluetooth à un ampli HiFi classique d'environ 20ans d'âge. En test audio depuis 3 jours. Parfait : le niveau d'entrée est bon, un peu plus faible mais bien. Le son est excellent. Comparé à un bon DAC à 200€ (très bien noté dans les critiques) sur une chaine HIfI de qualité classique, c'est très proche : même rendu des graves et des aigus, même présence des voix et des instruments, sonorité un poil moins ronde. Excellent rapport Qualité-Prix. L'avenir dira si la durabilité est bonne.
Hocine H.
Magnifique
Utilisé pour bretelle RCA de 60 cm, ce câble est bien un Mogami, détaillé, pur, précis, compléte parfaitement les câbles d'enceintes 3103 de la même marque. J'ai utilisé des connecteurs RCA Xangsane à 10 euros les 4 et je me retrouve avec une paire de câble de très grande qualité pour moins de 15 euros. Merci
Hocine H.
Pas mal
Bons connecteurs, de bonne qualité. Dommage que la soudure soit un calvaire si on souhaite souder le point froid car il est trop proche du point chaud (5mm environ). Ce même connecteur avec plus d'espace aurait été parfait car il est top pour ce prix.
michel m.
DAYTON AUDIO DSA115-PR Passive Radiator Aluminum 30.9Hz Ø10.2cm The Dayton Audio DSA115-PR is a passive radiator that can be used in a wide variety of installations, whether as a speaker or as a replacement for a similar defective model. A...
Renforce nettement les graves dans un caisson petit volume.
Guillaume V.
une très bonne surprise
je suis agréablement surpris par ce cable, je dois avouer que j'ai un faible pour les cables plaqués argent qui privilégie les aigus et médiums, ce qui permets des basses trés propre mais légèrement en retrait.
première paire de cable montés avec des fiches rca de la marque, trés satisfait de cet essai, je vais essayer une paire en xlr.
Guillaume V.
pas vraiment concluant
l'effet de pince est trop faible, du coup les fiches flottent un peu sur les connecteurs, pourtant les matériaux inspirent confiance et les soudures se font trés facilement, pas le cas de nombreuses rca.
par ailleurs l'utilisation avec le cable de la marque est vraiment satisfaisant pour ce qui est du son.
Dario G.
Dépanne bien, commode et pour un prix dérisoire.
Bravo audiophonics
Eric C.
FOSI AUDIO DA-2120C Amplifier Class D TAS5352A 2x90W 4 Ohm Bluetooth 5.0 Black With the  DA2120C , Fosi Audio offers a versatile and affordable  Class D amplifier . Its amplification stage allows it to deliver a power of  2x90W under...
Tres bon rendu.
Couplé avec des Spektor2 (Dali)
J'étais méfiant envers ces FDA.
Très bonne scène en Optique; du Volume et des basses que je suis obligé de moduler en fonction des enregistrements.
J'avais peur de basses électroniques, d'un rendu des aigus trop froid, trop clean-ique. Non, Impeccable.
Possible qu'a un volume au-delà de 65, ça sature. (suivant qualité de l'enregistrement) Je monte guère au delà des 40.
je ne me sers pas du Bluetooth; RCA décevant.
L'USB est surprenant en précision. L'optique: parfait (câble fourni relié à mon ordi)
Christophe H.
JANTZEN AUDIO COMPACT MKT 001-8080 Axial MKT Capacitor 160V 6.8µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Pour remplacement des médiums aigus sur filtre enceintes Cabasse Doris M2, en lieu et place des condensateurs d'origine Wishay MKT 1822 (verts). Le résultat est très bon. Les médiums et aigus retrouvent leur place. Les voix initialement criardes retrouvent leur ton (surtout les voix masculines, qui n'avaient pas de caractère et manquaient de texture). Les instruments et voix sont mieux placés et respirent. Ce n'est serte pas aussi dynamique, explosif et aéré qu'avec des Jantzen sup Z que j'ai monté sur des Dali Zensor 7, mais je dois dire que je suis assez surpris par la qualité. Pour ma part je trouve supérieure aux Jantzen cross cap et z cap. Ils sont plus neutres. leur valeur est exactement celle indiqué à 0,01micro farad près gage de qualité de fabrication. Cerise sur le gâteau si vous ne voulez pas vous torturer pour trouver une place sur le filtre, ils sont de taille modeste. Environ la même que ceux qu'ils remplacent.
