LB Aluminum Push Button with Red Light 220V Ø12mm Silver
1NO type button with red indicator light. Operates from a monostable mechanism. The connectors dedicated to the signal / power supply can support a voltage of 220V. Those dedicated to the power supply of the indicator light (LED) can accept voltages between 5 and 24V.
Reference : 17515
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 22-04-2025.
Push button
1NO 220V
LB Bouton Poussoir Aluminium avec Cercle Lumineux Rouge 5-24V Ø12mm Argent
An ideal part for your projects, DIY assembly, to repair / improve an existing device or build a control panel from scratch.
Schéma bouton poussoir
1PA66+GF20, V0 flame retardant
2Silver plated pins
3PA66+GF20, V0 flame retardant
4LED
5Locking hook
6Silver plated contacts
7Bushing
8Spring
9Latching mechanism
10PC, V2 flame retardant
11Silicon seal ring
12304 stainless steel stretch button
13Shell: H57/59 copper chrome plating
14Nickel plated hexagon nut
15Silicon seal ring
Schéma bouton dimensions et câblage
Product type1NO push button
Diameter of the screw thread12mm
Max panel thickness8mm
Total dimensions21.5*⌀13.8mm
LEDColor: Red
Voltage: 5-24V
Number of pins4
Voltage220V
LED ColorRed
Number of positions1
Button type1NO
1NO type button with red indicator light. Operates from a monostable mechanism.  The connectors dedicated to the signal / power supply can...
