Push Button with Red Circle Light 1NO 36V 1A Ø8mm Silver
This 1NO pushbutton is made from PA66, with a brass-plated copper body for perfect corrosion resistance, and silver-alloy contacts. It operates from a monostable mechanism and features a red indicator light (LED).
Reference : 17990
2,90 €tax incl.
2,42 € tax excl.
Shipping date: 25-04-2025.
Push button
With Red Circle Light 1NO 36V 1A Ø8mm Silver
Bouton Poussoir avec Cercle Lumineux rouge 1NO 36V Ø8mm Argent
The connectors dedicated to the signal/power supply can support a maximum voltage of 36V. Those dedicated to powering the indicator light (LED) will accept a voltage of between 9 and 24V with the 5kΩ or 4.7kΩ resistor supplied.
This push-button is an ideal part for your DIY assembly projects, to repair/improve an existing device or build a control panel from scratch.
Not suitable for main power switching. LED voltage values must be taken into account with the 5kΩ resistor supplied.
Product typeMonostable 1NO pushbutton
LEDColor: Red
Voltage: 9-24V
Total dimensions22*Ø10mm
Screw thread diameterØ8mm
Number of contacts4
MountingTo solder
Maximum switching voltage36V 1A
ColorSilver
Package1* Push button
1* 5kΩ resistance
LED ColorRed
Number of positions1
Button type1NO
This 1NO pushbutton is made from PA66, with a brass-plated copper body for perfect corrosion resistance, and silver-alloy contacts. It operates...
