R-CORE Transformer 100VA 2x115V to 2x15V 3A
This R-Core transformer is ideal to feed a DAC or preamplifier. It has a primary of 2x115V. Provided that the appropriate wiring is done, it will work as well on the European as on the American electrical network.
Reference : 15343
85,00 €tax incl.
70,83 € tax excl.
R-Core Transformer
Transformateur R-Core 100VA 2x115V vers 2x15V 3A
The values of the secondary voltages of the transformers are the nominal load voltages. No-load voltages will be slightly higher than those stated.
With its two secondary windings, it can supply several devices requiring the indicated voltages and intensities. There are two 15V windings with a maximum intensity of 3.5A for each. Moreover, it is equipped with a magnetic screen and an electrostatic screen.
Each cable is identified by a color code. This color code is detailed on a label glued directly on the body of the transformer.
Product typeTransformer
FormatR-Core
Power100VA
Primary winding (input voltage)(230V)
0-115V
0-115V
Secondary winding (secondary voltage)15V 3.5A
15V 3.5A
Dimensions124 x 104 x 57mm
CablesFlexible
24cm
Weight1890g
Mounting plateIncluded
Already mounted
Primary voltage (V)
  • 230.0
  • 2x 115.0
Secondary voltage (V)
  • 15.0
Power (VA)
  • 100.0
This R-Core transformer is ideal to feed a DAC or preamplifier. It has a primary of 2x115V. Provided that the appropriate wiring is done, it will...
