R-CORE Transformer 30VA 2x115 to 12-0-12V + 1x9V
Reference : 9750
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 24-04-2025.
Wiring instructions are to be found on the top label
R-core transformer
This R-CORE transformer is ideal to build a power supply for a DAC or a preamplifier.
It has 2x115V as primary widing. As long as the appropriate wiring is made, it can be used on the European power grid as well as the American grid.
It has three secondary winding that allows it to power multiples devices with different power specifications.
There is 12-0-12VAC (mid-point) secondary winding with maximum current of 0.7A.
There is also a 9V secondary winding with maximum current of 1.5A.
Moreover, it is equipped with a magnetic screen and an electrostatic screen.
Each cable is identified by a different color code. This color code is detailed on a label found directly on the body of the transformer.
Dimensions of the transformer
Mounting hole spacing 70x48mm
The values of the secondary voltages of the transformers are the nominal load voltages. The no-load voltages will be slightly higher than those stated.
TypeStep Down Transformer
FormatR-Core
Power30VA
Primary winding (input voltage)(230)
0-115V
0-115V
Secondary winding (output voltage)12-0-12V (0.7A)
0-9V (1.5A)
Dimensions78 x 70 x 40mm
CablesFlexible
200mm
Weight0.55Kg
Mounting plateProvided
Pre-installed
Primary voltage (V)2x 115.0
Secondary voltage (V)12.0
Power (VA)30.0
Bonne qualité
Fait le job
This review has been posted for R-CORE Transformer 30VA 2x115 to 12-0-12V + 1x9V
