R-CORE Transformer 30VA 2x12V
4.8 / 5
Reference : 8539
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 22-04-2025.
Wiring instructions are to be found on the top label
R-core transformer
This R-CORE transformer is ideal to build a power supply for a DAC or a preamplifier.
It has 2x115V as primary widing. As long as the appropriate wiring is made, it can be used on the European power grid as well as the American grid.
It has two 12VAC secondary windings with maximum current of 1.25A. Moreover, it is equipped with a magnetic screen and an electrostatic screen.
Each cable is identified by a different color code. This color code is detailed on a label found directly on the body of the transformer.
Dimensions of the transformer
Mounting hole spacing 70x48mm
The values of the secondary voltages of the transformers are the nominal load voltages. The no-load voltages will be slightly higher than those stated.
TypeStep Down Transformer
FormatR-Core
Power30VA
Primary winding (input voltage)(230)
0-115V
0-115V
Secondary winding (output voltage)0-12V (1.25A)
0-12V (1.25A)
Dimensions78 x 70 x 40mm
CablesFlexible
200mm
Weight0.55Kg
Mounting plateProvided
Pre-installed
Primary voltage (V)2x 115.0
Secondary voltage (V)12.0
Power (VA)30.0
10 reviews
Bon produit
Petit transformateur pas cher, belle qualité, la tension est respectée, 0.1v près, très silencieux et facile à mettre en œuvre. Attention à ne pas tirer sur les câbles de sortie, j'en ai malencontreusement arraché un. Ce transfo est tellement bien fait, qu'il est facile de le démonter, et de ressouder le fil, ce que j'ai fait.
Une petite amélioration : Un schéma des bobinages interne serait un plus, afin de ponter en série ou parallèle entrées ou sorties, afin d'avoir le meilleur couplage possible.
Merci Audiophonics pour la qualité de ce composant.
This review has been posted for R-CORE Transformer 30VA 2x12V
Good product
In combination with “ Linear Power Supply board MJE15034G Low noise 4.8V à 24V 2A" this transformer gave huge improvement in sound quality of my DAC e.a.
Transformateur R-CORE 30VA 2x12V
Bonjour,
J'ai déjà utiliser des transformateurs R-CORE, Jamais déçu.
Très bonne qualité, parfait pour l'alimentation de préamplificateur audio.
Juan
Excellent
Très bon transfo utilisé pour une PCB préampli à tube, branché en parallèle même si c'était inutile vu les besoins du préampli en courant.
Pas un bruit etc.Je recommande
Matériel conforme à la commande, livraison rapide, je recommande fortement ce site.
