Here is an external battery 3.7V / 3800mAh, specially designed and designed for your Raspberry Pi 3 / Pi 2. This battery has a dual USB-A output to connect directly to the Raspberry Pi. These two outputs are placed on the same side as the micro USB input of the Raspberry Pi, for an easy and short connection.
Theautonomy can go up to 9h! This portable battery can also be used to power small LCD screens, or other Singleboard Computer, it is sufficient to check whether the necessary voltage is delivered by the battery.
The screws and the spacers are provided to attach to a Raspberry Pi.
In order to charge this external battery, you need a 5V / 1A AC adapter with Micro USB cable. This micro USB 5V / 3A power adapter fits perfectly.
Features:
Dimensions and weight:
